Clip Effects Enabled by default
I've noticed that when I open a session in PT12.6 that clip effects are enabled by default. Is there anyway to disable this (no mention in the manual)? At the moment the only way to do so is to show every track in the session, select every clip and bypass or disengage all the clip effect modules. Not terribly difficult but a bit inconvenient.
I run HD Native so I need to squeeze every bit of processing power that I can from my CPU. Unless AVID confirms that leaving the clip effects on with the factory setting does not take a hit on processing power then it'd be nice if there were a preference setting that disables it. |
Clip Effects - Compression Metering?? | off the wall | Pro Tools 12 | 8 | 09-30-2016 09:59 AM |
Clip effects not working [SOLVED] | cshaw | Pro Tools 12 | 5 | 09-30-2016 05:22 AM |
11r default settings for effects, how change them? | t6ygfr5 | Eleven Rack | 11 | 04-14-2011 03:44 PM |
Transfuser on the master fader with ADC enabled makes bpm effects out of sync. | Rubicon | Virtual Instruments | 6 | 09-25-2008 10:43 AM |
Soft Clip enabled? | airwavejoel | Tips & Tricks | 0 | 05-09-2003 07:11 AM |
