Mbox Line Inputs Balanced TRS ?
Are the line inputs on the Mbox balanced TRS, what level are they at? +4 or -10?
And, is it possible to plug two sets of headphones into the Mbox? One into the 1/8" front connector and another set into the 1/4" back connector? |
Re: Mbox Line Inputs Balanced TRS ?
I'm trying to get digi to answer this question.
Jerry, man, you need to get the Micro Box .pdf file. It's on Digi's CD they mailed out...
I'll peek & see if this info is on there... Peace BTW Can someone explain (to this rookie) how the Mbox "mix pot" works?
A Blues Harp and PowerBook is all I need ... along with Analog Signature Pack & BlueTubes 3.0 !! |
From the mbox .pdf :
__________________________________________________ ___ Analog Inputs - 2 * Separate source selection and gain control per channel * MIC/LINE/INST (DI) input - XLR/1/4" combo connector * Phantom power (48 V) * Mic pre-amp:>-120 dB EIN @ > 40 dB gain * Hi-Z input for instrument pickup * Maximum Input: 3.5 VRMS (balanced signal), or + 13 dBu Headphone Output * Separate volume control - both 1/8" and 1/4" connectors * > 0.25 w into 600 ohm __________________________________________________ __ Peace
mix pot allows you to make a mix between the audio coming from protools and the instrument you play.
Example: you have recorded everything except vocals. Make a nice headphone mix in protools. record enable the vocal-track and mute it!!!! then with the mix-pot you can make a mix between the vocals and the rest of your music. They do it like this to make sure you have NO latency issues when tracking
What's that? - That's the machine that goes "pling". Bastiaan |
Thank you Bastiaan !!!!
You da man... Peace & Happy Super Bowl
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:<HR>Originally posted by Jerry Finklestien:
Are the line inputs on the Mbox balanced TRS, what level are they at? +4 or -10?<HR></BLOCKQUOTE> Yes, the Analog inputs are balanced (XLR / 1/4" TRS combo connectors). The gain of the analog inputs are continuously variable so there is no reference calibration level. <BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:<HR>And, is it possible to plug two sets of headphones into the Mbox? One into the 1/8" front connector and another set into the 1/4" back connector?<HR></BLOCKQUOTE> -In short, No, it's not designed to drive two headphones. The Mbox does have two headphone outputs, however plugging into the 1/4 inch jack on the rear panel disconnects the mini-jack on the front panel. You could plug a Y-cable into one of the jacks but the amount of drive is limited. Brent |
>"-In short, No, it's not designed to drive two headphones."
No biggie for me... Peace
Are the Mbox 3 Pro line inputs too hot? | bcent15 | FireWire & USB Audio Interfaces (Mac) | 8 | 07-26-2015 07:18 PM |
Mbox 2 Pro - Unbalanced/Balanced Inputs | Dstryr | FireWire & USB Audio Interfaces (Mac) | 0 | 04-25-2013 03:19 AM |
Adding line inputs to my Mbox 3 Pro | Ferrante | Pro Tools 10 | 10 | 12-25-2012 06:04 AM |
Mbox 3 line inputs not true | strangedaysuk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 02-15-2011 07:59 PM |
MBox Pro Line inputs: Balanced/unbalanced | LincolnT | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 09-06-2009 09:40 AM |
