Old 07-27-2023, 07:20 AM
JoeTools1963's Avatar
JoeTools1963 JoeTools1963 is offline
Default 32 Bit Float
Hi all
I am sure the 32 bit float workflow is the bane of many of our work lives.
I am working with a director that is shooting in loud environments, as an example ships, prop planes and diesel vehicles.
He insists that he has better luck recording in 32bit float, which I get given the headroom.
That having been said, they are editing in Premier Pro and can only export AAF in 24bit. So, it does not work well for me in PT.
Any suggestions?
I am on the latest PT HD running on an Apple M1 Max. 32 Gigs Ram. Interface is a simple 2 channel Scarlett as these series are only broadcast stereo.
Cheers
JT
Joe Tools
Re-Recording Mixer/Sound Designer
Nova Scotia Canada
OS Ventura 13.0
Pro Tools Ultimate 2022.12
Mac Studio Max 32GB Ram
OS 10.8.5
Pro Tools HD Accel Version 10.3.8
Mid 2012 Mac Pro 5,1 32GB Ram
Old 07-27-2023, 07:28 AM
its2loud its2loud is offline
Default Re: 32 Bit Float
There have been many discussions on the DUC regarding 32bit workflow. Unless you plan on importing the audio from the original 32bit sound rolls from production, your 32bit workflow will be broken at the point when the editor imported the audio and sent you the AAF/OMF to mix. You will be working with 24/48 files most likely.
We also already covered this in your other thread here a month ago.
https://duc.avid.com/showthread.php?...ighlight=32bit
Old 07-27-2023, 07:31 AM
smurfyou smurfyou is offline
You'd have to use Ediload or Kraken, some external tool to assemble from an EDL and the original files.
Not hard but not a quick and easy built-in solution either. I guess the main question is are you missing some benefit of 32 bit float? Or is everything coming over from Premier OK and you don't need the original files? For me it would depend on the complexity of the show and most importantly the budget/deadline.
~Will
Old 07-27-2023, 01:33 PM
mfranken's Avatar
mfranken mfranken is offline
Sounds In Sync
An EdiLoad assembly doesn't take long at all to do if the required metadata is in tact, now that version 5 can export a PTX file with all clips ready for editing. I would however recommend requesting a XML file from your editor as the EDLs exported from Premiere Pro are quite limited.
Regards,
Mark
Mark Franken, MPSE
Dialogue editor/supervisor IMDb
Creator of 'EDI' applications for sound post editors
www.soundsinsync.com
Old 07-27-2023, 08:20 PM
minister's Avatar
minister minister is offline
Just adding a few thoughts as others have given you the answer...
32 bit float does not change the relationship of the recorded voice source vs recorded noise source. NR still has to work on that level. Just another example of someone not understanding audio and handing it to you.
If you want 32b files, EdiLoad v5 is the way to go. And, in fact, the new V5 is now wicked powerful and easy to use (once you learn it). Sessions made with EL V5 are really slickly assembled so you can get working quickly. I just did a decent budget feature with Deva files made by a person who setup all the metadata correctly and it all came together nicely.
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
Undertone Custom Sound Libraries
"Groupable markers would be epochal!"
-Starcrash
Old 08-14-2023, 02:51 PM
The side note is, they are shooting a television series on hot rods. They are recording at 32 bit float in an effort to avoid overloading the recorder input. The issue is, the wireless has a built in limiter that cannot be disabled. That overloads, so a moot point in the end.
Joe Tools
Nova Scotia Canada
OS Ventura 13.0
OS 10.8.5
Old 08-14-2023, 07:57 PM
That I am familiar with! Needs an experienced recordist not 32 bit
~Will
Old 08-15-2023, 03:46 AM
Roger that and concur.
Joe Tools
Nova Scotia Canada
OS Ventura 13.0
OS 10.8.5
Old 08-15-2023, 04:22 AM
JFreak's Avatar
JFreak JFreak is offline
Everything is always so damn hot, except the volume knob...
Janne
Old 08-15-2023, 06:23 AM
Hahahaha!!! Yup
Joe Tools
Nova Scotia Canada
OS Ventura 13.0
OS 10.8.5
HTML code is On
24 or 32 bit float Bender macOS 26 03-13-2018 06:41 AM
32 Bit Float boogiemotel macOS 76 01-20-2013 09:28 PM
32 Bit Float boogiemotel Pro Tools 10 28 01-09-2013 10:22 AM
32 bit Float Logichead Pro Tools 10 0 10-22-2011 11:08 AM
Help! What is a 32-bit Float Mix ????? Rhapsody 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 02-27-2010 09:46 AM
