I hoped 2023 would have fixed the bounce Mov Crash :-(
I'm on a M1 Mini Studio HD Native and the " feature" that crashes PT after each bounce to Mov has been a real drag. Last week I worked on 26 versions of a spot. So Bounce, deactivate Video Engine, Reactivate Video engine was getting boring and time consuming. I updated to 2023.6 hoping it would have solved things but no.
Re: I hoped 2023 would have fixed the bounce Mov Crash :-(
I have never been able to reproduce this issue, and I bounce out review Quicktimes dozens of times a week. I am on the latest PT with an M1 Ultra Mac Studio
I have had zero crashes (as long as you don't extend past video for your selection or have blank frames internally due to editing the video; the last one only Ultimate users can do)
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
Then I did a bounce of audio only of the same film which was only 2.5 min long for a TV thing. that caused crash also. I'm digging into it for Avid tomorrow. I have a ticket into them and they seem to think it was fixed and know that I worked on the fix with them with crash reports and testing. So, we will see, since it had not been happening in 2023.3 that I remember and especially not with just and audio bounce. the Codecs I use are all qualified rasters. ProRes422 etc. I will post more when I get done. Will check Natively on this show and Rosetta 2, as it was in Rosetta 2 that it happened. Running a Mac Studio Ultra etc. see my profile for my info. G
Composer/Sound Designer/Protools 2024.3 Ultimate, MTRXII-TB3, DADMAN MOM, Cisco SG350-10MP EthernetHUB, KLANG:quelle 4 Channel Dante™Headphone Amp, DVS,MADI, Mac Studio Ultra,128 RAM/4TB SSD, Ventura 13.6.6, DP 11.3.1, Logic Pro X 10.8.1 DOLBY ATMOS Facility/MPSE Motion Picture Sound Editors Avid Certified Professional ProTools/Dolby ATMOS |
Are you doing same-as-source or are you rendering?
Good point-:)
I have had it happen on both though.. G
Ok, I primarily work with the dreaded MP4. It's what I get and I'm usualy getting prep minutes before session start and often updated picture during the session.
PT doesn't offer "Same as Source" and is greyed out for me. Also, I usually Bounce to PCM. It sounds better and I use Simian which automatically converts files on upload and bouncing to AAC has effected the sound quality for me. |
I bounce out the audio, then use Shutter Encoder. Load in the audio and the delivered MP4, select "Replace Audio". One extra step, but way faster than BTQT in PT.
I use Shutter Encoder to make MXF and import that into PT for working. Most efficient video format. To export a short clip, less than the full length of the video, then I will BTQT, then drop the exported video into Shutter Encoder and convert to H264. Ship that to client.
Tom Hambleton CAS Ministry of Fancy Noises IMDb Undertone on Facebook Undertone Custom Sound Libraries "Groupable markers would be epochal!" -Starcrash Last edited by minister; 06-19-2023 at 05:42 AM. Reason: Added info |
I am not sure why the editor can't just send you a proper .mov format with the mix prep you receive. Seems odd to me. I always have a set standard setup well in advance as to what works for me and communicate that to producers. You can again aways transcode the QT after you do a "same as source" version. Not understanding why yours is greyed out for transcoding or is it a case of not being a certain ver of ProTools? I have to have everything to run my business here to expidite the workflow, which is key for us here. G
Composer/Sound Designer/Protools 2024.3 Ultimate, MTRXII-TB3, DADMAN MOM, Cisco SG350-10MP EthernetHUB, KLANG:quelle 4 Channel Dante™Headphone Amp, DVS,MADI, Mac Studio Ultra,128 RAM/4TB SSD, Ventura 13.6.6, DP 11.3.1, Logic Pro X 10.8.1 DOLBY ATMOS Facility/MPSE Motion Picture Sound Editors Avid Certified Professional ProTools/Dolby ATMOS Last edited by gives; 06-23-2023 at 07:48 PM. |
structure & 2023.6 - crash | Fritz | macOS | 8 | 09-12-2023 09:31 AM |
Today's AIR FX and Instrument 2023.3 updates re-install 2023.2! | off the wall | Pro Tools | 9 | 03-28-2023 10:33 AM |
BFD2 Win 7 64bit ProTools 8.0.5 crash FIXED! | ozchapman | The Drum Room | 2 | 12-18-2012 12:29 AM |
something i hoped never to see again | ivanmil | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-08-2007 11:08 PM |
CoreAudio Crash on waking - will it ever be fixed? | penx | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-11-2005 05:13 PM |
