Old 05-18-2022, 12:49 AM
@tention @tention is offline
Default State of h264/265 support in PT
Guys maybe you can chime in with your experience here.
I occasionally work on TV shows that just need a little care from the sound department. They are usually VERY long (3hrs+)
For my other jobs I usually ask for DnxHD, but the amount of data just seems inappropriate for those kind of jobs.
Do you have any experience with the state of h264/5 support in PT 2022.4 and could maybe hint me into a more workable solution?
Thanks
SOUND!
Old 05-18-2022, 07:48 AM
diamondschwin diamondschwin is offline
Default Re: State of h264/265 support in PT
I use H264 on long and short form… definitely a bit sluggish compared to ProRes or DNX but it has not been an issue for me. Haven’t worked with H265 yet.
Max Holland
Producer / Re-Recording Mixer
Nashville / NYC
MKD Creative
Old 05-18-2022, 08:42 AM
gives's Avatar
gives gives is offline
Thanks
ProRes or ProRes 422 is the standard editors send me in LA work I do, especially for longer form. 422 is compressed for size, but very accurate. I can't afford to mess around. H.264 is the safe bet if you want to know.. H.265 is pretty new and not everyone can open it. It's good for storage though.
Composer/Sound Designer/Protools 2024.3 Ultimate, MTRXII-TB3, DADMAN MOM, Cisco SG350-10MP EthernetHUB, KLANG:quelle 4 Channel Dante™Headphone Amp, DVS,MADI, Mac Studio Ultra,128 RAM/4TB SSD, Ventura 13.6.6, DP 11.3.1, Logic Pro X 10.8.1 DOLBY ATMOS Facility/MPSE Motion Picture Sound Editors Avid Certified Professional ProTools/Dolby ATMOS
Old 05-18-2022, 06:53 PM
smurfyou smurfyou is offline
Playback sync is sloppy and scrubbing is choppy. General sluggishness. I avoid it whenever possible but it can be done.
I feel like H265 has been a little better but it probably depends on the bit rate and keyframe interval.
Always remember to check your video sync offset when you change codecs.
~Will
Old 05-18-2022, 08:16 PM
minister's Avatar
minister minister is offline
Thanks
Ask for an H264 or H265 and convert it yourself.
Use this.
https://www.shutterencoder.com/en/
Done.
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
Undertone Custom Sound Libraries
"Groupable markers would be epochal!"
-Starcrash
Old 05-18-2022, 11:01 PM
BScout BScout is offline
Better (lighter/smaller) than ProRes or ProRes LT is ProRes Proxy. 44% the size of ProRes LT. And for audio work, pretty great looking. I don't bother with the others. It's the closest to DNxHD36 rates (which was the standard for Skywalker)
Still won't be as small as h264/265 but smooth as silk.
And, yeah, I'll take anything submitted and convert it with ff-Works (another program, like ShutterEncoder, that is a ffmpeg GUI front end -- they both use the same "engine" so should be the same speed to do decoding/encoding)
Old 05-19-2022, 08:00 AM
gives's Avatar
Use this.
Done.
Yes a great product I also like this one as well especially for ProRes and it's fast.
http://www.ffworks.net
G
Old 05-19-2022, 08:57 AM
TVPostSound's Avatar
TVPostSound TVPostSound is offline
Use this.
Done.
Definitely encode your own!!
Ive been real happy converting to DNXHQ
IMDB
Old 05-19-2022, 01:20 PM
Adobe Media Encoder is a great conversion tool (among many other things)
If you have an Adobe subscription, check into that. Its what I use, mainly because lots of people in picture departments are using it as well.
Max Holland
Nashville / NYC
MKD Creative
HTML code is On
H264 Codec zoing123 Post - Surround - Video 23 04-08-2013 02:16 PM
Support for SSD (solid state drives) Ed Spoto VENUE Live Sound Systems 3 04-19-2012 02:01 PM
Need Help with 59.94 H264 pix with 29.97 OMF amptbuddy Post - Surround - Video 6 01-27-2009 05:34 PM
Need Help with 59.94 H264 pix with 29.97 OMF amptbuddy Post - Surround - Video 2 01-26-2009 09:06 PM
qt h264 tape2tape Post - Surround - Video 1 02-08-2007 05:32 PM
