Old 08-09-2012, 09:35 AM
mds1001 mds1001 is offline
Default Mbox 3 Pro has super hot line inputs?
Hey guys,
Doing some basic testing of my setup I noticed that if I run a signal into my line inputs it comes it WAY hotter than if I send the same signal from the same source in via S/DIF. I'm running an API A2D and if I take a line out into the line it is much louder than the same signal running into S/PDIF.
Anyone know why this is? The way I have it set both should be at unity gain.
Thanks!
Old 08-09-2012, 07:57 PM
Default Re: Mbox 3 Pro has super hot line inputs?
I suspect its the difference between analog and digital. Analog outs on the API are likely set for +4, while the SPDIF out(for the same level) would be closer to -12dbFS
Old 08-09-2012, 10:38 PM
Hmm, interesting. I'm seeing about 5db different on the levels, though I haven't run a sine wave through it so I'm not sure the exact difference.
Are the Mbox 3 Pro line inputs too hot? bcent15 FireWire & USB Audio Interfaces (Mac) 8 07-26-2015 07:18 PM
mBox 3 Pro mic inputs go from quiet to super loud rsandifer FireWire & USB Audio Interfaces (Mac) 0 08-28-2013 09:15 PM
Adding line inputs to my Mbox 3 Pro Ferrante Pro Tools 10 10 12-25-2012 06:04 AM
Mbox 3 Pro has super hot line inputs? mds1001 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-09-2012 10:00 AM
Mbox 3 line inputs not true strangedaysuk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-15-2011 07:59 PM
