Old 02-10-2000, 07:17 AM
Camilo Orozco's Avatar
Camilo Orozco Camilo Orozco is offline
Default ProControl & NT
Anybody using ProControl with PT5.0 NT???
What Protocols and components must be installed under NT to comunicate with Procontrol???
Any help will be much apreciated.
Camilo Orozco
Camilo Orozco
Like us on www.facebook.com/artedigitalestudio
www.estudiodegrabacion.com.mx
Old 02-12-2000, 12:00 AM
DPierce DPierce is offline
Default Re: ProControl & NT
We found there were drivers that needed to be installed that were not easily found. We called Tech Support and found out where the drivers that came with the software we located. We had a hard time finding them, but once found and loaded, everything communicated properly.
Hope that helps.
David Pierce
KLOVE Radio
Old 02-12-2000, 07:36 AM
Thank you David,
Are the drivers in the PT5.0 CD-ROM???
Any help will be apreciated.
Thanks.
Camilo Orozco
Old 02-15-2000, 04:40 PM
I believe they were, but as I remember they were not easy to find. Hidden away. If you call Tech support they should be able to direct you to the right location. But they were critical for the two to work properly.
David
Old 02-16-2000, 07:06 AM
Thank you David,
I went thru the instalation and everything worked OK!
Camilo.
Camilo Orozco
ProControl with 7.0/7.1 LE (procontrol.dll etc) eccles ProControl, Control|24, Command|8 0 09-17-2010 12:06 AM
ProControl or C24 guitar012001 ProControl, Control|24, Command|8 3 08-09-2009 05:02 PM
ProControl with LE? megahurt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-30-2007 12:13 AM
6.7 and ProControl Will Russell ProControl, Control|24, Command|8 1 11-05-2004 04:37 AM
What ProControl should/could be: johnnyv ProControl, Control|24, Command|8 0 11-06-2001 10:45 PM
