AMD CPU Choices
As mentioned in my Harddrive Choices post I am building a PT system with an Mbox. Allen's under $600 system seems great due to it's price. And the Allenstein machine seems like it would keep up with most anything. I'm trying to have a system that will be used for PT and audio apps only (like those reason, etc). Any processor speed recommendations here? Any overclockers? I haven't tried overclocking and wondered how stable it was.
Thanks for all your help!
Big Sur 11.7.4, Pro Tools Ultimate 2023.6, HD Native, 2010 Mac Pro 5,1 3.46ghz 12 core, 128GB RAM, Radeon RX 580, 970 Evo M.2, 860 Evo, and Angelbird SSD drives. All PT optimizations followed to the letter. Ventura 13.2.1, Pro Tools Ultimate 2023.9, M2 Pro Mac mini, 32GB RAM, 1TB SSD. |
Re: AMD CPU Choices
Anyone? Any opinions of Athlon 64's vs. XP's?
Re: AMD CPU Choices
I'm overclocking. It only get me a coule more tracks on the dave c though. I am running a variant of the under $600 machine. And it is running just great. If you use the A7v600 you can use an AMD 3200+ cpu.
Asus A7v333 133*16.5 2.25GHZ AMD 2400+ Matrox G450 512 MB Micron 2700 RAM 60 GB 7200 RPM 60 GB " " 32+7 dave C |
Re: AMD CPU Choices
If you can afford it...go for the 64bit solution. Its more powerful and more upgradable. I used to have a XP system and my 64 craps all over it.
Further...go for the socket 939 series if you can afford it, because, I'm led to believe that there won't be any more revisions of the socket 754 after the 3700+. The 939 is up to 4000+ already. AMD are going to move the 754 chips over to the Semperon Platform for the next couple of years etc.
DIGI002 MSI K8N nForce3 25Ogb Athlon 3200+ (1Mb L2) 1 Gig PC2700 Corsair Memory 120 gig Ext USB 2.0 32+14 DaveC PT 6.9 |
Re: AMD CPU Choices
I agree, go AMD 64, and 939...
Ill suffer winter alone; ten thousand miles from home... |
Re: AMD CPU Choices
Hi, I'd second that notion for socket 939, and you may want to wait for the new nforce4 chipset that will come out in another month or two. It will support SATA II (300MB/s transfer rates), and PCI express. Overall, it will be a bit faster. The 939's are supposedly going to be easier to overclock, if that is a goal of yours.
That being said, overclocking and new technology don't necessarily make for the most stable environment. If you've got clients depending on you, it may be best to go with tried and true. I got my MSI k8n neo platinum/AMD 3000+ (socket 754) a month ago. I've dabbled with overclocking and have overclocked by about 10%. It's pretty stable, though I may back down since I'm not having problems running plug-ins. I don't know if I'd reccommend this mobo though, because many users have been disappointed with its performance; little bugs have been listed on their forums, and it doesn't really OC that well. A nice feature though is Nforce3's native sata support, which allows you to boot from an SATA drive w/o a floppy. The next VIA chipset will also support this. |
Re: AMD CPU Choices
I've noticed a tremendous difference with my 64 vs my XP. Mine is also one of the 64's with the 1MB cache instead of 512k like all the new Athlon 64's have. It's so much faster than my XP.
So many choices. | Terry Wetzel | General Discussion | 8 | 12-16-2011 10:21 PM |
Drum recording: 3 room choices, 3 channels, 4 mic choices - pls lend your advice!! | edgarbc1 | Tips & Tricks | 4 | 12-03-2009 08:40 AM |
Choices!, Choices!, Choices! | dwdrummer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 12-22-2002 11:09 AM |
DAW choices - help! | henryhill | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 10-10-1999 09:27 PM |
