Re: Constant 9173 error's PT 12.6
I have the same problem! Will check my plugins too
Gesendet von iPhone mit Tapatalk Pro
My ears! My ears! clausiii ----------------- MacBook Pro i7 Quad 2.6GHz 16GB RAM ProTools 2020.11 Avid S1 Avid Dock Avid Control Digidesign Command|8 macOS Catalina MOTU 4pre MOTU Track16 Axiom Pro 25 LinnStrument 128 Roli Seaboard Block tons of stomp boxes tube amps guitars noise |
Re: Constant 9173 error's PT 12.6 *solved*
If you're going start doing a lot of install/uninstall, it will be a good idea to image your system drive first.
All you have to do is change the buffer to a different setting. No reboot or anything like that required. I just switch between 512 and 1024 back and forth as needed. |
Same weird workaround here aswell. Change buffer size to anything doesn't matter and then back again solves it for us. Have no clue why this is still happening though
I've seen this in Logic, should try for the weird spikes in PT
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019 amagrasmusic.com |
If you make them inactive, settings will remain. If you remove them from the inserts, non-default settings will be gone
People,
I think this Probleme is not (!) solved. Is it my job to test every single plug in if it works 100% fine with this very sensible AAX engine? NO !!! I payed so much money for the PT HD 10/11/12 Software and updates. Avid, please do your job. I have 100s of Plug ins of renowned manufacturers. Waves, Soundtoys, Slate, Sonnox, McDSP, Softube, UAD. It takes hours to check every plug in. Thats no solution.Yes, I can confirm that some plugs work better than others, but these plug ins works much better in every other DAW. I thought some years ago we changed the plug in format from rtas to aax to get better compatibility with plug ins. But today many plug ins works 50 or 80% "fine". I think its a Pro Tools Problem. Such a "unclear" Problem exsisted in any other previous version of Pro Tools. Please integrate a clear AAX Plug in verification in Pro Tools that show us if a plug in work correct or not. these CPU peaks are so frustrating. I have a lot of Sessions where i can not work on."9173 error" all the time. But I have to finish a album. Terrible ! Please, please, please help us !!! Aaaaaavid Heeeeeelloooooo !!! |
You need to develop a rapid as possible testing approach to your problems. Start by checking all plugins are up to date, trash prefs, etc. Systems fully optimized, try doing all other tricks folks have tried here. Getting rid of Click II, etc. You on 12.6? That better or worse than 12.4? Then pull all plugins out and confirm you can run stable sessions at all, if so then put them back and pick obvious suspect/high risk plugins and pull them out of the session. And yes start with UAD. And if this happens on some session and not others, and Save Session In does not fix that, then you can start to triangulate what common plugins are running in those session issues, make a spreadsheet if that helps. It may well still be a very broken version of Pro Tools, but you need to work out how to do what you can do to make progress. And if you finf a flakey plugin the first place to go is that plugin vendor support. |
www.HellfireBeats.com UAD 2 Apollo Quad w/Thunderbolt 3, UAD 2 Satellite Octo TB3, UAD 2 Octo PCIe, Avid S1, Neve R6 500 Chasis, Neve Portico 511, Neve Portico 551, Dangerous DBox+, Focal Trio6 Be, Neumann TLM49, Akai MPC 2000XL, Akai MPC X, Mackie 1202VLZ Pro, Akai Advance 61 Pro Tools 2021.12 Mac Pro 7,1 2019, 8 Core, 48GB RAM - MacOS 11.6.2 16" MacBook Pro 2021, M1 Pro, 16GB RAM - MacOS 12.1 27" iMac, Late-2012, 3.4GHz i7, 24GB RAM - MacOS 10.15 |
AAE error -9173 on PT 12.4 | marcnyc | Pro Tools 12 | 2 | 06-24-2016 03:27 PM |
-9173 error in PT 12 | ArKay99 | Pro Tools 12 | 10 | 06-11-2016 01:41 AM |
Error -9173 | music.m | Pro Tools 11 | 1 | 03-19-2015 09:42 AM |
PT 11 Clearly Not An AAE 9173 Error | rgconrad1 | Pro Tools 11 | 3 | 09-29-2014 11:56 PM |
i7 Macbook Pro - 11.0.2 / 11.0.3 constant -9173 errors | A Chapman | macOS | 13 | 12-18-2013 09:36 PM |
