Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2019
Old 12-28-2019, 03:14 AM
mandal mandal is offline
Default 2019.12 & Video
Gurus
Regarding 2019.12 Ultimate & Video
When I import a DNxHD video (the first time) I receive...
But next time I try - to import the same DNxHD video - everything works ok !!
Please advice
Avid OMNI PCIe
Pro Tools Ultimate 2020.5
Avid HEAT
Dell 43" 4K LED P4317Q
CPU: Intel Core i9-10980XE
Motherboard: Gigabyte X299X AORUS MASTER E-ATX
Cooler: Be quiet! Dark Rock PRO 4
RAM: 64 GB Crucial Ballistix Sport LT DDR4
Screen card: MSI GeForce GTX 1660 VENTUS XS OC
Cabinet: Fractal Design Define 7 XL Black
Disk1: Samsung 970 PRO 1TB M.2 SSD
Disk2: Samsung 840 PRO SSD
Disk3: Samsung 860 EVO SSD
Power: Corsair RM750x, 750W PSU
Microsoft Windows 10 Home 64-bit OEM DVD
Old 12-28-2019, 10:27 AM
gives's Avatar
gives gives is offline
Default Re: 2019.12 & Video
I have seen this also. Some strange things like video freezing etc.. ALSO,
I had to convert to another format and lower data rate, which I had been using a lot. Not sure what's happening here, but got it finally to work
Gregory Ives, Composer/Sound Designer/Musician
http://www.gregives.com
https://pro-labs.imdb.com/name/nm1170521/?ref_=sch_int
Protools 2020.9 Ultimate HD Native Thunderbolt Avid HD IO
Mac Pro 3.5GHz 6-Core Intel Xeon E5 64GB of Ram
OSX Mojave 10.14.6, Digital Performer 9.5.2, Logic Pro X 10.5.1
Old 12-29-2019, 03:14 AM
bartosz idzi bartosz idzi is offline
you could try wrapping that DNxHD in a MXF container.
http://www.shutterencoder.com/en/
https://www.pro-tools-expert.com/hom...talina-support
Mac Pro 2 x X5690 3.46Ghz - 64 Gb RAM - SSD 256 Gb - SSD 1TB - OS 10.14.6 - Metric Halo 2882 + Lucid 88192 - Pro Tools Ultimate 2020.9
Old 12-30-2019, 03:10 AM
Yes, I did exactly what Production Expert show here...and generated a MXF formatted media suitable for Pro Tools 2019.12 - now it works !!!
Encoding to DNxHD.
https://www.youtube.com/watch?v=ZiUm...w&index=3&t=0s
But I thought this workaround only was necessary for computers running macOS Catalina...
And Shutter Encoder didn't have the same option when encoding to DNxHR (not able to generate a MXF from a MP4 - GoPro 4K)
Avid OMNI PCIe
Avid HEAT
Old 12-31-2019, 10:21 AM
Ale Ale is offline
Do you have the video loop error with dnx mxf?
Ale
3x PT HD Ultimate 2020.03 6/12-Core Westmere/ 48 GB / OS 10.13.6 / 96 I/O / 192 I/O / Omni / BM Intensity Pro (Driver 11.4.1)
1x PT 2019.6 / MacMini Server late2011 / 16 GB / OS 10.13.6 / 002
www.tonstudio-gress.de
www.facebook.com/TonstudioGress
Old 01-01-2020, 11:55 PM
Ale
I'm not sure what you exactly mean by loop error...
But in Windows 10 - the MXF in DNxHD works ok for me.
Avid OMNI PCIe
Avid HEAT
Old 01-02-2020, 07:40 AM
JanuS JanuS is offline
Not the same problem, but related to PT 2019.12 & Video:
I run my video on a Mac Mini as a satellite system.
Mac Mini was running Mojave, I updated to PT 2019.12, but I got nothing but black image. I downgraded to PT 2019.6, and everything was fine again.
Looking at the Mojave update 10.14.6, I noticed there was a Mac mini specific update to prevent video go black "in certain circumstances".
I updated to 10.14.6, updated PT to 2019.12 again, and now it works fine!
So, for Mac mini users experiencing trouble with video: update to Mojave 10.14.6
Old 01-07-2020, 10:07 AM
jlascotty jlascotty is offline
I also had a similar issue...
Working on Imac 2012 with black video window issue.
Updated to 10.14.6 then was offered the option to download an update to pro video formats via software update on the mac.
This seems to have fixed the issue.
Problem enabling video engine 2019.6 Lydbildet Windows 12 04-02-2020 10:24 AM
Bug in new video engine 2019.10 Meads Post - Surround - Video 40 03-23-2020 08:36 AM
2019.10_ Video starts then goes black js_nyc Pro Tools 2019 5 11-09-2019 09:17 AM
PT 2019.5 Video Quality and Frame Blending ShaneG Pro Tools 2019 6 06-14-2019 02:46 AM
PT 2019 same video problems garnoil Pro Tools 2019 12 05-12-2019 03:50 PM
