#21
Re: Vocal Compression ???
#22
I have the TLM49 and it suits my voice. I only do voiceover primarily for radio and TV commercials and corporate videos, not singing. It replaced my Rode K2, which, again on my voice, it suited too. I've actually matched an old read I had to replace some dialogue on that was originally done on the K2. Depending on how you work the TLM49, it can approximate the sound of a tube.
I've also used the TLM49 on a female VO and it was great on her voice too. Is it for every voice and vocal chain? Certainly not and, as always, YMMV. My chain is: TLM49>Grace m101>RME UFX>Pro Tools I save any and all processing for plug-ins, if requested by a client. Otherwise, clean and uncolored and as recorded and the client does the processing and mixing. BTW, I had a DBX286A in the beginning of my home studio days 16 years ago. I didn't have it long. I sold it because it had too many variables to change to dial in a sound I and my clients liked, doing it by myself. I just went the clean and clear route. Again, YMMV.
#23
For uncoloured sound, I use Neumann KMS105 mic into Focusrite ISA preamp. I have ISA1/ISA2/ISA8 to choose from, but they're all pretty much the same, except ISA1 is special :) point being, I like to shape the sound after recording.
I don't have the ISA4 but if someone has a bargain please offer me on PM :)
#24
BTW, if you go shopping for an ISA-428, try to buy the Mk II version. The original(with the VU meters) uses a conventional power supply that runs VERY HOT and will fry things inside from the excess heat. The Mk II version uses a switching supply that stays way cooler(junior) and sound is the same(and the old digital option card WILL work in the newer unit)
#25
What has this whole thread to do specifically with PT 10 ?
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 , Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060 |
#26
From what I have read, absolutely nothing Maybe a moderator should move it to the General section
#27
I have PT10 & this is where I spend a lot of my time.
By all means if it could help other es feel free to move it. L |
#28
#29
well, as long as it works, it does make a great hand warmer
#30
Yep. I find it warms the sound too...
Vocal compression help | Mattitude | Tips & Tricks | 14 | 03-18-2010 02:12 PM |
Vocal Compression | cdavis6406 | Tips & Tricks | 11 | 03-30-2008 05:28 AM |
LE vocal compression | Sharritan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 02-23-2005 05:30 AM |
Compression for Vocal | Daniel P | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 08-27-2003 10:43 PM |
Vocal compression | Voutsonios | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-03-2001 11:05 PM |
