  #6511
Old 02-16-2017, 08:02 AM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: i7 Builds - Specs and Results
FYI - SSD's have been officially blessed by avid as the record target drives
Samsung 840 and 850 Pros here and working good
Daniel
  #6512
Old 02-16-2017, 08:15 AM
newptbuild newptbuild is offline
Awesome, so we might just grab another larger SSD to record on as well. Did you get a chance to look at the build?
  #6513
Old 02-16-2017, 09:20 AM
YYR123's Avatar
Looks great, PM guitar don with Pro Tools PC
I believe he has experience with that CPU.
I know my LGA2011 chipset has flawless with PT.
So I assume the LGA2011 -3 will be stellar as well, but hit Steve up just to make sure
Daniel
  #6514
Old 02-16-2017, 02:55 PM
gnjlee gnjlee is offline
Originally Posted by Pique Arestiuvee View Post
I'm thinking of going ...
Anybody out there running Pro Tools 12 on Windows 10 with a 6950x or 6900K? If so, is it solid? Do you use a ton of virtual instrument inserts and effect inserts and write a lot of MIDI with no problems?...
Thanks!
My new system has a 6900k. I haven't recorded with it yet, and I haven't done any MIDI or VMs at this time, but I just did a mix with it. On a project with 40 audio tracks and 120 waves and ozone plugs combined, I use about 12% CPU @ buffer around 256 on PT 12.7. Absolutely stunning performance.
  #6515
Old 02-17-2017, 11:41 AM
Pique Arestiuvee Pique Arestiuvee is offline
Thanks!
  #6516
Old 02-19-2017, 06:34 AM
zavid zavid is offline
No pro tools HD or HDX cards on your system ?
only pro tools native and Cpu Win/Hackintosh ?
the sound is same as processing with HD or HDX cards ?
(without audio data "compression"/downsize/reduction)
z.
  #6517
Old 02-21-2017, 10:23 AM
z.
No HD on my system. I can't justify the cost. Just PT 12.7 Vanilla with Windows 10, build 1607.
  #6518
Old 02-22-2017, 03:46 AM
thanks for reply ,
then you bounce to LR only with computer cpu ?
z-
  #6519
Old 02-22-2017, 12:33 PM
thanks for reply ,
z-
Only with the computer.
  #6520
Old 02-28-2017, 04:57 AM
the reason why lot of used pro tools HD cards and interfaces
are for sale around ?
z.
Best Core 2 Series Desktops-Results and Specs sunburst79 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2416 02-19-2013 07:49 PM
new to pc builds chazc080488 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 10-18-2011 07:10 PM
any p45 builds fofif5792 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-09-2008 12:47 PM
OSX "builds" Richard Barrie Pro Tools TDM Systems (Mac) 2 10-18-2004 08:37 AM
