Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 06-24-2016, 07:06 AM
risey's Avatar
risey risey is offline
Default Scarlett 18i20 2nd | Promblems | Fixes
I was fortunate enough to get my hands on the Scatlett 18i20 2nd gen, however I must warn you there are asio related problems in PT 12 but after extensive hands on for many hours yesterday I managed to overcome with the following method.
Software Is Currently In Alpha:
1. There are 2 USB drivers, one will lock your buffer at 128, the other file focusriteusbinstaller_1.exe will work.
2. You must ask Focusrite for the ALPHA Focus Control version Focusrite Control-1.1.1.1297
3. Set up your ins / outs in Focus Control, click device settings and ensure the sample rate matches the session you are about to start in pro tools, also take note that the USB is locked and in sync shown with a green light.
4. Before using the unit, power down the PC, turn the 18i20 on, power up pc
5. Right click the Focus Control and run as administrator
6. Load up your Pro Tools Session, go to IO settings and default them
7. If you have no sound, do not close session, go to the buffer in pro tools, if your using 512, change it to a lower or higher rate then back again to 512 or the buffer you had for your session.
8. If you receive an ASIO error, this device is not configured or set up properly error then it is most likely caused by you not powering the unit on first before powering up the pc and using focus control with admin rights.
9. The Asio errors seem random, you may get them even after following the guide I created above, however for me the unit worked 8 times out of 10 following the steps above.
Good Luck
Ryan
http://www.PhatMonkey.me
Windows 10 64bit | Asus Rog Hero Xi | Intel i9-9900K | Corsair LPX Vengeance 64g DDR4 RAM | Avid Mbox Pro 3 | Focusrite 18i20 2nd Gen | MSI RTX 2080TI Gaming X Trio | Acer Z35 Predator Monitor
Old 06-27-2016, 04:28 AM
hooksound hooksound is offline
Default Re: Scarlett 18i20 2nd | Promblems | Fixes
Hi Ryan.
Thanks for the info. It looks like you have been very patient in order to get it to work.
However, this is bad news in the sense that I was expecting that Focusrite would have used the jump from 1st to 2nd edition to eliminate these problems that plagued the 1st edition Scarlett range. Last year I bought an 18i20 1st edition, but had to return it, because of these issues.
I have now pre-ordered an 18i8 2nd edition in hope that it will perform out of the box. Fingers crossed.
Pro Tools 10.3.10, Cubase Artist 7.5.40, Allen & Heath Qu-16, Focusrite Scarlett 18i8 2G, Fujitsu Lifebook AH532, Intel Core i7-3612QM, 8 GB RAM, Windows 7 Professional SP1 64 bit
Old 06-27-2016, 06:08 AM
WillFocusrite WillFocusrite is offline
Hi Ryan,
A very small number of 2nd generation Scarlett 18i20 units have been shipped to our dealers early – these units are not actually supposed to be available until the beginning of July. The alpha version of software that you have is designed to get you going, but did not undergo full testing, so there could be some issues with it. We will have a fully tested version of the software available on the release date of July 1st.
Sorry for any inconvenience this may cause.
Thanks,
Will
Focusrite Tech Support
Focusrite scarlett 18i20 madselhoff Third Party Interfaces 6 01-25-2016 04:45 AM
Pro Tools 11 with Focusrite Scarlett 18i20? hermonmusic Third Party Interfaces 24 06-27-2015 08:53 AM
Scarlett 18i20 and USB 3 on Mac JCBigler Third Party Interfaces 1 11-09-2013 07:07 PM
Could you help me with this, please? - Calibrating a Scarlett 18i20 hermonmusic Getting Started 4 09-13-2013 08:33 PM
Mbox Pro 3 vs Scarlett 18i20 Help me decide! hermonmusic FireWire and USB Audio Interfaces (Mac) 11 08-09-2013 09:02 AM
