Old 12-08-2009, 09:20 PM
micline micline is offline
Default Running out of CPU power on Quad Core?
Hello All,
I have exhausted all my options and I need help.
Today Protools started giving me trouble, Tons of CPU overload errors, and losing communication with he 002. but the CPU meter is only at 22% I have a session I am working on that has mostly audio tracks and 3 midi instruments.
recently I installed the Digitranslator2 I had an old ilok license that had an authorization on it from when I owned the AVID STUDIO TOOLKIT.
the problem coincides with the Digitranslaotr install however after removing the OMF.Bundle File the problem still persists
I have repaired permission
trashed prefs all prefs using the database helper
trashed databases and volume
restart, and Still.
The machine is a
Mac PRO Quad Core 2.66
4GB RAM
OS 10.5.7
Protools 8.01
Digi002
and Euphonix mc control
any thoughts?
Thanks
Old 12-08-2009, 10:08 PM
djkiller djkiller is offline
Default Re: Running out of CPU power on Quad Core?
i'm runnning a session as we speak on a quadcore and no issues. i usually set my buffer sample rate between 128-512 and then 3 cores and put a check in the error box to avoid errors popping up and coming up in a session. then i set my disk buffer to 0 and when i'm in playback and mixing i go between medium and high on the cache size. i use a good amount of tracks, midi and aux buss. however i always print my midi to audio by sending it to an aux and then out to record it. i usually start from what i just said and play around with it.
Old 12-09-2009, 01:30 AM
eyrespace eyrespace is offline
Methinks you may have some incompatible plug ins. Try removing all third party plug ins and see if that clears it up.
Old 12-09-2009, 03:31 AM
001tony 001tony is offline
I had an issue a while back and poster here, someone explained about certain plugins working overtime due to silence or near silence. Turned out to be a dverb...
think that protools is prone to this as I remember Protools keeps the plugins active all the time, apparently some other DAWs don't.
It may be worth bypassing plugins one at a time to see if the problem persists.
Latest Project Here:
http://www.youtube.com/watch?v=G0OEwoLAbOg&feature
Old 12-09-2009, 04:14 AM
tamasdragon tamasdragon is offline
As in this case it was working right before, I think it can be easily an os related problem. Try downloading the free onyx app, which can maintain mac osx well.
Any plugins recently installed?
my blog:Tamas Dragon
Old 12-09-2009, 09:33 AM
Hello All,
Thanks for the reply's
Funny thing about this is that, it has been running like a top since PTLE 8 came out. never a hiccup. Now all of a sudden....
I installed DigiTranslator, and all this starting happening. so I removed it, but it still happens. I had the CORES set to use all 4, so I knocked that down to 3, that seemed to help
Also it is not session specific, I started a new session, I put 8 Virtual instruments on it, and played, it will play back all 8 for about 10 secs then it stops and throws the CPU error at me even though the CPU meter is only at 30%
I checked the plug in versions using Digi's very cool updater, it said all my plug ins and software are up to date.
Any thought's now
Old 12-09-2009, 02:11 PM
best bet is to run through the suggested digi setup you can find in the top of the threads as well there is a link to a nice cleaner in there. also if i remeber correctly on a mac on your second drive you need to set it to non journaled or something like that so it reads as just a dump drive and not something you're running programs on but check the thread to be sure.
Old 12-10-2009, 02:09 AM
BRH BRH is offline
Don't Virtual Instruments load up into RAM?
8 VIs with 4GB of RAM?
I think you should get more RAM.
Old 12-10-2009, 02:12 AM
Have you tried trashing prefs&databases after removing digitranslator. Onyx is a very good free app to maintain your os.
If we cannot narrow down the problem, than you should uninstall/reinstall pro tools.
Old 12-10-2009, 10:37 AM
DigiTechSupt's Avatar
Originally Posted by micline View Post
Hello All,
Any thought's now
Which VI's are these? It sounds like you have incompatible plug-ins installed or possibly ones that can't run entirely on an RTAS dedicated processor.
Please use the Tech Support Utility to generate and post a list of installed plug-ins and we'll take a look...
Avid Audio Tech Support
Support FAQ
My new Mac Pro 8 Core is running out of CPU power (-9128)??? Alexvenusa 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 16 02-26-2010 10:08 AM
Mac Pro Quad 3.0ghz 4 core vs. Dual Quad 8 core? AllThingsMusicStudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-04-2008 08:22 AM
Looking at getting Quad Core 3.0 GHz, running Leopard 10.5.1 Ruzzo Pro Tools M-Powered (Mac) 3 04-27-2008 08:15 PM
Single core vs. dual core vs. quad core John Peeples Tips & Tricks 9 11-07-2007 03:28 PM
live recording on quad core g5 power mac bl_nd m_c General Discussion 1 04-19-2006 01:53 AM
