Old 07-06-2009, 05:46 AM
j20056 j20056 is offline
Default HUI drops after Mac standby mode
Is there a workaround? I use a Tascam DM4800 as a control surface in HUI emulation mode. After standby, HUI no longer sees the control surface, even if I quit and restart PTLE 8.0cs3. Only fix is to restart the machine.
Is there a better solution?
Digi002 Rack
Mac Pro 8-core 3Ghz
8gb RAM
3X 500GB 7,200 SATA DRIVES
OSX 10.5.7
PTLE 8.0cs3
Old 07-06-2009, 09:25 AM
Default Re: HUI drops after Mac standby mode
Turn off standby, sleep, screen saver and any other feature that takes the computer off line.
Old 07-06-2009, 11:34 AM
Thanks. Although I appreciate the answer, that much I had figured. So I guess the reality is that it is considered normal behavior and there is no other solution then. That's ok, I just wanted to make sure. One of the PT "idiosyncracies"...
Digi002 Rack
Mac Pro 8-core 3Ghz
8gb RAM
OSX 10.5.7
PTLE 8.0cs3
Old 07-06-2009, 11:35 AM
Why screen saver BTW? I may not mind turning off the standby mode, but screen saver should have no impact does it?
Digi002 Rack
Mac Pro 8-core 3Ghz
8gb RAM
OSX 10.5.7
PTLE 8.0cs3
Monitoring in 003 Standby Mode? bentropy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-12-2008 06:39 AM
Monitoring in 003 Standby Mode bentropy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 11-11-2008 06:32 AM
DIGI 002 stuck in standby mode! BillyP 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-26-2006 08:11 PM
001 preventing my PC from going into standby mode. scoobydoo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-02-2006 08:17 PM
standby record mode (to rnt_u_listnng) love666 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-31-2001 11:19 AM
