Old 07-05-2009, 09:48 AM
emulin emulin is offline
Default If I wanted to run ADAT in, is there a reason to choose 003 over 002?
Hello - I recently got an mbox mini to try out pro tools to see if I liked it.
I do! So now I am wanting more than two inputs.
So here is my thought.
My set up is based around a MOTU 2408mkIII and II. I do not want to get rid of those I think.
So I am thinking that I could get a used 002r and put the mkIII in ADAT mode and use that for my inputs.
It seems to me an 002 would be good enough in this scenario.
Does this make sense or is there something I am not considering that would make the 003 better in this scenario?
Old 07-05-2009, 11:26 AM
Default Re: If I wanted to run ADAT in, is there a reason to choose 003 over 002?
A used 002R will be a bargain and should work just fine. Plus, you could always send it to Black Lion Audio for the upgrades at a later date. Just be aware of the power harness issue with the 002 units.
Old 07-05-2009, 12:00 PM
Gothboy's Avatar
Gothboy Gothboy is offline
The 003 has wordclock while the 002 doesn't but it works just fine for me.
Apple Mac Pro 2.88 GHz. Intel Xeon Quad core
16 GB RAM
Mountain Lion 10.8.5/El Capitan 10.11
Focusrite Saffire Pro 40
Ableton Live 10/Presonus Studio 3
Old 07-05-2009, 03:42 PM
The Dougfather The Dougfather is offline
This isn't applicable to revision G units and above, you can tell rev by the last digit of the serial number.
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D
iCON Photography
Old 07-06-2009, 07:28 AM
j20056 j20056 is offline
What ias the "power harness issue" and the mentioned upgrade? I have a 002R from 2005.
Digi002 Rack
Mac Pro 8-core 3Ghz
8gb RAM
3X 500GB 7,200 SATA DRIVES
OSX 10.5.7
PTLE 8.0cs3
Old 07-06-2009, 09:41 AM
Ah yes I remember hearing about the power harness issue. I will look for a revision G unit -- THNKS FOR THE TIP!
Thanks everyone for the feedback. I will start watching ebay and see if I can snag one of these in my pricerange.
Old 07-06-2009, 09:47 AM
amorlando amorlando is offline
the origianl power harnesses had a connection issue that would build up resistance on the molex pins, hence with more resistance and a current load, the voltage would dip causing the power supply to "fail" and not fully boot. very common on many modern power supplies.
Studio Troll
Old 07-06-2009, 11:18 AM
Jamtime Jamtime is offline
Thats great news to me! have a G unit.
But, all my potentiometers are crackeling from oxidation when turned. Have tried electric cleaning spray with absolutely no success.
Is this also a common problem? How to fix?
Sorry for borrowing your thread but I hope it can give you some help to!
/Micke
I voted at www.deardigi.com
Drummer of Yamaha Birch Absolute Custom Nouveau Vintage Natural - Zildjian K Custom Dark - Sabian HH
Macbook (2009-01) 2.0 GHz 4 GB
Intel Quad (2007-07) Q6600 2x250 4 GB
PT 8
Digirack 002
Monitors: JM-Lab Electra 906 & SW900 driven with Pioneer Reference M-90
"Semiprofessional user"
Digidesign ADAT AD/DA Converter wanted! Who´s in? clausiii 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 11-22-2004 09:35 PM
Reason-ADAT edit-001 MartinC 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-24-2002 10:03 AM
reason w/ ADAT edit MartinC 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-08-2002 12:17 AM
sound cards using ADAT with Reason EddieDingle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-03-2002 11:15 PM
Wanted: ADAT I/O card with DSP capabilities .... phobia 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-24-2001 01:27 AM
