Old 10-09-2014, 07:24 PM
j20056 j20056 is offline
Default Learn Mode in EQ3 plugin not working
I am trying to use the rotary encoders of a M-Audio Oxygen8 to control the frequency levels of the EQ3 7 band plugin. I know that the Oxygen is properly setup because the Midi message window in BFD3 plugin correctly shows a CC message increasing from 0 to 127 when I rotate the knob.
However, when I select LEARN from the EQ3 and rotate the same knob, nothing happens.
Any idea what to do?
Digi002 Rack
Mac Pro 8-core 3Ghz
8gb RAM
3X 500GB 7,200 SATA DRIVES
OSX 10.5.7
PTLE 8.0cs3
Old 10-10-2014, 07:08 PM
GregV GregV is offline
Default Re: Learn Mode in EQ3 plugin not working
I'm not sure but I'll take a stab at it...
Your first step should be turning on that parameter for automation. I think once it is on you can select the CC number that will control it.
In the track view on the Edit page, if you can't select the desired parameters, then you can't edit/automate them.
I hope that helps
Old 10-10-2014, 08:10 PM
Not all plugins allow for Midi-Learn(and EQ III is one of those). I just tried it and the option is not available, but it IS available on the DB-33 plugin(I have a VOCE midi drawbar unit that controls the plugin very nicely).
Some external controllers can be used, but they need to be setup in Peripherals(consult the manufacturer manual for that setup).
Old 10-11-2014, 06:00 AM
albee,
In my EQ3 window, I do see a LEARN button that turns red when I push it, and to the left of it, there is a drop down with a choice of EQ3 parameters to be selected. Alternatively, I can click on the virtual button of the parameter to be learned. After I do sound rotate a knob on my Oxygen8, and deselect LEARN to finish the learning, nothing happens.
I dont understand why and where I would need to manually set a CC number when that's what learn is supposed to do.
I also tried doing the same thing on the AIR EQ and nothing happens either.
This is frustrating and I have no more ideas.
PS: I did check the plugin window and also selected most EQ3 parameters to be enabled via automation. I know my Oxy is sending CC because BFD3 is picking them up.
Digi002 Rack
Mac Pro 8-core 3Ghz
8gb RAM
OSX 10.5.7
PTLE 8.0cs3
Old 10-11-2014, 09:01 AM
nst7 nst7 is offline
You are confusing Automation parameters with Midi control.
They are two completely different things. Again, most plugins do not have Midi learn, including EQ3. They only ones that usually do are Virtual Instruments, and certain types of plugins like guitar amp simulators, that would lend themselves to being controlled by midi interfaces. There are exceptions (for example, Fabfilter has midi learn on all their plugins), but generally, most plugins do not have it.
Automation is a completely different thing, and virtually all plugins have automation parameters.
Old 10-14-2014, 06:57 PM
OK, so let's say I am interested in EQ3 automation. Doesn't it mean that I would be able to assign a control surface encoder to a plugin parameter, then record the automation while using the encoder? I'm trying to do just the first step here which is to assign the encoder, as I don't care about recording what I do with it.
How else would you use automation, short of drawing levels in the edit window?
PT does offer M-Audio keyboards as an interface type, and as soon as I select it, the LEARN button appears in the plugin window.
So what am I kssing?
Digi002 Rack
Mac Pro 8-core 3Ghz
8gb RAM
OSX 10.5.7
PTLE 8.0cs3
Plugin learn feature disappeared Moviesound ICON & C|24 2 07-28-2011 11:23 AM
PT9 crashes after mapping plugins in learn mode luiger 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-18-2011 09:40 PM
LEARN MODE has got me in a stew! MD_MUSICMAN 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-11-2010 04:10 PM
LEARN MODE has got me in a stew! MD_MUSICMAN Pro Tools M-Powered (Mac) 0 02-08-2010 05:44 PM
Plug in / Instrument learn mode converted 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 01-08-2009 06:35 PM
