Old 11-30-2010, 11:33 AM
allgenres allgenres is offline
Default No audio signal or midi signal after pro tools 8.04 upgrade
I am desperately in need of help. Previously i was using the 8.03 upgrade. I was experiencing some issues. Pro tools has never ran incredibly smooth for me, but im used to it. I use the ASIO drivers for our DAWs mostly for production. The biggest issue with 8.03 is that if i dont start my 003 before my laptop is on, windows freezes and i have to do a hard restart. I never had this issue with 8.0 or 8.01. Obviously that gets annoying, so i decide to upgrade to 8.04. Everything seems to be working great. Vista even recognizes the 003 as a soundcard, so im able to play music through itunes, firefox, etc. When i open pro tools, or any other DAW, and record enable a track, there is no signal whatsoever. I turn the gain knobs up on my 003 just to see if there is a signal and there is. There is also no midi signal being sent to the DAW. I installed the CS update and still nothing. I NEED HELP! im probably going to have to go back a version or 2, but i was hoping someone could provide a solution before i had to. PLEASE HELP!!
thank you
Old 11-30-2010, 11:51 AM
spkguitar's Avatar
Default Re: No audio signal or midi signal after pro tools 8.04 upgrade
You have the 003 console, not the 003 Rack? The 003 drivers are still single client drivers. While you can use the new drivers for other audio applications, it's still only one at a time.
I would (personally) recommend setting windows to use a standard soundcard for all generic audio applications (iTunes, etc) and patch the output of the soundcard to the aux in of the 003.
Also, are you sure you have the latest drivers for the 003?
Old 11-30-2010, 04:41 PM
I have the 003 rack, and im using the stock sound card as the default in windows. i assumed that the latest drivers came with the 8.04 CS2 update? is there somewhere else i should look? i appreciate your help
Old 12-01-2010, 08:03 AM
Help us Help You - READ THIS Before Posting!
You have not given anywhere near enough info. If you are running Windows XP, I would go back to 8.0.1 with cs2.
Old 12-01-2010, 08:08 AM
System DetailsEdit Value
HP dv9500
Intel Core 2 Duo T7500 @2.20Ghz
2GB RAM
Vista Business SP 2 (32 bit)
Pro Tools LE 8.04
003 RACK
does that help?
Old 12-01-2010, 08:58 AM
TOM@METRO's Avatar
HP dv9500
2GB RAM
Pro Tools LE 8.04
003 RACK
does that help?
Not enough. What Albee is asking for is a Sandra report as described in the thread that he pointed to. This will give us the hardware information that may help us help you.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
aux track signal but no midi signal? elv1s1sal1ve 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 07-06-2005 07:18 PM
No Midi signal, no audio signal, buzzing monitors! 1tonstudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-26-2004 07:01 AM
No signal when recording MIDI after upgrade to 6.1 Bobbi Tube 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-27-2004 05:33 PM
synced with pro tools- see signal, but can't hear signal- HELP!!!! hitwriter 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-30-2002 10:08 PM
Can Audio Signal Go Through Midi Cable flymax MIDI 7 03-02-2001 02:14 PM
