HD12.7.1 stability insights
For background I am a career PTHD user of ten years, running my own commercial studios and travelling to various studio's. I recently overhauled my age'ing PT10 system and traded up to a HDX1 running PT12.7.1 on a 5,1 MacPro 3.06 12-core, 48gb ram running OS10.12.3. I'm having chronic issues with the instability on this system, main ones listed below;
I have been through various topics on DUC and have some points of discussion/questions that I wanted to put forward.
Any insight would be gratefully appreciated! Cheers Al Last edited by algroves; 04-07-2017 at 04:43 AM. |
Re: HD12.7.1 stability insights
at a glance, your HDD spinner running at 5900rpm is likely the cause of most of your issues, 7200rpm is the base minimum... if PT can't retrieve the data fast enough {made worse if the HDD is fragmented} it'll kick up all sorts of errors.
Start there and report back, 7200rpm data drive a pretty cheap these days and work well, just make sure there's no power management built into the drive firmware, if the drive spins down and goes to sleep, it'll cause issues as well. |
Not sure how many third party plugs you use but you need to update them to their latest versions.
C
PT 2021.10 HDX 16x24 -Mac Pro 12 Cores 48 GB RAM OS 10.13.6 - API 16 channel - AMS Neve 16 channel, AMS-Neve-SSL -Pres/Processing, Bock Audio, BLUE Bottle, Neumann, Josephson -Mics, Bogner, Kemper- Guitar, Chandler Zener-Curve Bender Outboard/Master. UAudio, Waves, Plugin Alliance etc. |
EVERY SINGLE TIME you update either PT or operating system, you should really go through all of your plugins and check for new versions.
True about the old plug ins. And they can cause problems whether you're using them, or not. The slow drive could be a problem but I often use 5400RPM drives without problems as long as they're USB3 and the session is not too large.
Steve
Steve Shepherd Extreme Mixing |
I've partitioned my boot drive (a 512 Apple SSD) into 2 256GB partitions. One (MAIN) has macOS 10.11.6 and PT 12.6.1, the second (APLHA) has macOS 10.12.3 and PT 12.7. I don't use Sierra (ALPHA) in my any of my work. I find it unstable and running the same session on both partitions, the session on Sierra uses about 10-15% more Native CPU than the EC partition. As I do the occasional MIDI track, I'm also partial to PT 12.6.1 as it handles MIDI without the compensation errors of 12.7.1. To be clear - both partitions (MAIN & ALPHA) have current versions of all plugs and both partitions plug directions are exact matches. I'm waiting for the next version of PT to see if they fix the MIDI issues (again) and see what macOS it pairs with. Meanwhile - my own anecdotal experience is that on Xeon based Mac Pros, EC 10.11.6 is the best performer. YMMV. Good luck!
T- ----- Waterstreet Studio Main: MacPro 2012 ([email protected]), 48GB, Apple/Samsung SSDs, WD Blacks. macOS 13.3 DSP & IO : Pro Tools HDX2(2018.3), 2x UAD Octo, HDIO 16x16 Analog IO(3), HDIO 16x16 Digital IO Plugins: Avid, DMG Audio, Kush, oeksound, P'n'T, Plugin Alliance, Softube, SoundTheory, Sonnox, Sound Radix, SoundToys, UAD, VEP, etc Hardware: API, Chandler, Hardy, Moog, Neve, Shadow Hills, Smart, Summit, TC Electronic M6000, UREI, etc Microphones: Telefunken, Neumann, Shure, AKG |
HD Native Pcie, PTHD 11, PT12 Vanilla, Omni, Lynx Aurora 16, 192 I/O (16 in/8 out), 24 Fader D-Command, lots of preamps and compressors. MacPro 5.1 (12) Core (2009 MacPro 8 Core Upgraded to a 12 Core MacPro), 56 Gig Ram, SSD System & 3 - 2TB Drives, OSX 10.9.5, Windows 10 Via Bootcamp |
Cheers |
This was a totally fresh install on a brand new machine, and all the plugin/software installers were downloaded fresh from the manufacturers websites. So I'm assuming they are all the most current versions. |
totally joking BTW!! whoever sells those upgrade kits owes you a commission! |
FS: Protools HD12 with ilok | 11miles | Buy & Sell | 7 | 08-08-2016 12:26 PM |
How to upgrade from PT HD11 to PT HD12 | clemens | Licensing & Accounts | 1 | 02-02-2016 07:43 AM |
bit the bullet on a PT HD12 upgrade | Bookerv12 | Pro Tools 12 | 2 | 12-27-2015 02:59 PM |
stupid HD12 or non-HD12 upgrade question | adam_w1 | Pro Tools 12 | 11 | 11-02-2015 04:24 PM |
