Opening a session created on another system
I have a question. Sorry if this has been covered. We have 3 studios, 2 with HD 2 and 1 with a LE system. We have purchased the Glyph key drives for all the rooms in order to swap sessions. The problem is, that if a session is started in one room and opened in another room, PT complains that it cannot save because I do not have access privileges. I can "save a copy as" and make a new session, but that kind of defeats the purpose of using the swap drives. Is there a trick to saving a session after opening it with another system?
All are Macs running OSX 10.4. thanks, Joel |
Re: Opening a session created on another system
check your permissions on that drive after you insert it into the new computer. also, check in the workspace to make sure that the drive is designated "R" and not "T". AND, repair disk permissions on all computers if you have not done so already.
hope that is helpful.
Tom Hambleton CAS Ministry of Fancy Noises IMDb Undertone on Facebook Undertone Custom Sound Libraries "Groupable markers would be epochal!" -Starcrash |
Sorry, but I don't understand. To my knowledge disk permissions are only able to be repaired on drives that contain the OSX system. These audio drives don't have permissions to repair.
I don't know what the workspace is or how to designate a drive as "R" or "T". I do repair permissions on all computers about once a month. I did so again today. Also, this happened today by copying a session over ethernet from one room to another, not by pulling the glyph drive. Sorry for the faulty information. Thanks for the input. I will look up the workspace in my "OSX Missing Manual." Joel Quote:
Ahhhh, sorry, workspace is a digi thing not an OS thing. My bad. I am new to PT. I found my workspace and the drive is "R" not "T"
Thanks for the tip! joel Quote:
While in the Finder, Get Info (Apple+I) on the Glyph volume. Tab open the Ownership & Permissions section, then click the checkbox next to Ignore ownership on this volume. Now, when you move that Glyph drive from one system to another, OS X won't care about the username that is associated with the Pro Tools file, and it will work just fine.
Thanks,
I really appreciate the help! Joel Quote:
Problem Opening Session created on PT HD 8 | sheckybass | Windows | 3 | 06-04-2012 12:21 PM |
opening midi session created in 7.3 in 8.0 | guitardom | MIDI | 6 | 07-02-2011 10:03 AM |
problem opening session on OS9 that was created in PC | c0yle | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 11-28-2009 11:06 AM |
Opening session created on PC with my MAC? | Faulty Records | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 10-17-2007 10:41 PM |
Opening a session created on a mac | Dopamine | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 10-31-2004 05:52 PM |
