Old 02-08-2003, 01:48 PM
OneMadSon OneMadSon is offline
Default Trashing Preferences, Rebuilding Desktop Advice
I've been having some issues with Protools freezing up and giving me the tapping fingers when I press stop while in record mode. I'm running a mirror door G4 with 002. I've followed advice found here and reinitialized my non-system hard drive where I kept my sound files and also trashed the digi, protools and DAE preference folders. I have two questions:
1) What does trashing the preference folders actually do? I like to try to understand why something works.
2) I've seen advice from Where and others on "rebuilding your desktop". How do you do this and why does it help?
Also, is there a good book or resource anyone recommends on caring for the G4.
Thanks
One Mad Son
The only difference between me and a madman is that I am not mad S. Dali
Old 02-09-2003, 06:59 AM
soundboy69 soundboy69 is offline
Location: From: Trinidad (Humboldt Co.); living: somewhere between Chicago and St.Louis...
Default Re: Trashing Preferences, Rebuilding Desktop Advice
Hi. If you're looking for a good book for your Mac, get "The Macintosh Bible". Make sure you get the most recent one that includes Jaguar (10.2).
It's a treasure trove of info on feeding and caring for your Mac and it's operating system.
The other questions are good, too. It's good to know why something works...if anyone can share, I'd like to know, too. [img]images/icons/wink.gif[/img]
soundphaRm
Old 02-09-2003, 07:19 AM
DesertDude DesertDude is offline
Apples knowledgebase answer rebuild desktop
you can search here for all your Mac questions
[img]images/icons/cool.gif[/img]
DesertDude
1.25 Alu/1.5 ram/10.3.4
PTLE 6.4-002R-Live-Reason
Old 02-09-2003, 08:24 AM
where02190 where02190 is offline
Your problems aya also be with your mirror door logic board, which many have had problems with on the mirror door models. check with Apple regaring your specivif erial number and PT compatibility.
to rebuild the desktop, hold down the apple and option keys while starting up.
to reset PRAM, when starting up hold down apple, optin P and R keys, and after the third chime let go.
I recommend rebuilding the desktop daily, or wheneve ryour mac acts funky, and zapping PRAM weekly.
Both of these are standard Mac PM. read the manual, get a Mac bible, and learn about the workings of your computer.
Hope this is helpful.
Old 02-10-2003, 12:54 AM
Ben Jenssen's Avatar
<font size="2" face="Verdana, Arial">It just forces PT to make a new settings file. It contains things like buffer settings, preferences settings (!), some midi settings (not oms), but its much less than you might think. You wont notice much difference after trashing the prefs, but after a little while, you will. Its just a small inconvenience. Try to look over things if you have trashed prefs, before you start to work.
And just as a curiosity:
I have many a-time tried to trash my PT and DEA prefs to solve problems the last few years, and when I have found that the problem had nothing to do with them, I put them right back. So, I actually have the same prefs as I had at least an upgrade or two ago. This is just to hint that trashing the prefs might not be the "give PT a new start" that some seem to think.
Just to be presise:
You only have to hold opt-cmnd (or option-apple) just as the desktop and the first disk appears to rebuild desktop.
Life-long audio enthusiast and small studio owner, now retired.
Mac mini, quad core i3, 3.6 GHz (Late 2018), 16 GB RAM
128 GB internal (2500/550 Mbs r/w)
1 TB external (425/425 Mbs r/w).
Focusrite 2i2 3rd gen, Dynaudio BM6's, Command 8, a couple of mics.
Pro Tools 2020.5, Mac OS 10.15.6.
Old 02-10-2003, 03:19 AM
kav kav is offline
From Apple KB:
Contents of PRAM
Contents of PRAM are as follows. Some Macintosh computers may not have all the settings described below.
* Status of AppleTalk
* Serial Port Configuration and Port definition
* Alarm clock setting
* Application font
* Serial printer location
* Autokey rate
* Autokey delay
* Speaker volume
* Attention (beep) sound
* Double-click time
* Caret blink time (insertion point rate)
* Mouse scaling (mouse speed)
* Startup disk
* Menu blink count
* Monitor depth
* 32-bit addressing
* Virtual memory
* RAM disk
* Disk cache
Don't zap your PRAM weekly - it doesn't tend to sort out out most common problems anyway.
Rebuilding the desktop - rebuilds your desktop database file which is a file that keeps track of the files and their whereabouts on your system. If you are constantly creating / adding /deleting files on your system then you could probably do with rebuilding 0nce a week /two weeks because the database file gets quite bloated with redundant information.
G4 350 sawtooth
512MB ram
OS 9.0.4
PTLE 5.1.1
PB G4 867
256MBRAM
PT FREE
Old 02-10-2003, 05:37 AM
<font size="2" face="Verdana, Arial">It really depends on your usage. the more data you run through your mac the more frequently you need to zap PRAM and rebuild desktop. You can't do any damage doing either as often as you want.
Trashing Preferences jryser macOS 0 12-17-2011 12:56 PM
What if when you were trashing preferences... Wheeltard 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 12-28-2010 12:28 PM
Trashing Preferences paul_g 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-23-2009 06:56 PM
trashing preferences temb0 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-25-2009 04:27 PM
Rebuilding your desktop Integrate Pro Tools TDM Systems (Mac) 7 08-08-2000 12:19 AM
