Old 10-28-2016, 05:05 AM
Default Re: Pro Tools 12 and SSL Nucleus interface issues
Originally Posted by swingfingers View Post
I've had this same issue for over a year which has led to me leaving my Nucleus turned off. The Nucleus would lose communication at some point during every session which would eventually lead to a force close of PT's because PT would hang when trying to close the program after the Nucleus would lose communication.
I think I recently found the fix:
http://www2.solidstatelogic.com/stud...l1-7#&panel1-7
The fix on a Windows 7 machine is to make sure and run PT with "Administrator level privileges". I made this change roughly five days ago and my Nucleus has not lost communication once since this change. SSL outlines how to make this change in the above link.
Follow the link to the FAQ page on SSL's Nuclues troubleshooting page. The section is titled:
"Why is Pro Tools not communicating with my SSL control surface in Windows 7?"
I hope this helps.
'Run as admin' is one of those things that can fix a myriad of issues and certainly worth a shot. If you're on a single user computer there's no reason not to run as an admin account full time.
Jack
QAPLA!
Old 11-16-2017, 05:23 AM
DetroitT's Avatar
DetroitT DetroitT is offline
Originally Posted by Mick335 View Post
ANOTHER UPDATE:
Hi. Well, just in case anyone DOES ever have this problem, I have not resolved it yet, but at least I now know that I am not alone!
I went back to SSL, and they ran PT12.4 under Windows 7 on a Dell Latitude. They had exactly the same problem that I so!
There is no 'fix' yet, but at least I feel better that I am not totally crazy!
So, it seems to be a Pro Tools / Windows 7 combined issue. I'm thinking about upgrading to Windows 10, to further test the issue... though deferring for now! I cannot imagine what issues Windows 10 will bring!
I'll send another update if I EVER get to the root of this.
Thanks.
A nice control surface with Major Pro Tools Avid and SSL flaws (MIDI of IP VODo)
Duality is not any better util you buy into the Delta plug-in/hardware/Firmware
SSL and Avid loosing the battle here.
Thanks, Mick.
Old 01-08-2018, 01:12 PM
Mick335 Mick335 is offline
Hi folks. One more update. Although I went over to Mac in the end (which resolved the problem) it was an old machine, and now I have Universal Audio plug-in issues (disabling), so... I tried the Windows PC again, but with Windows 10.
And...as it happens, exactly the same problem, so Windows 10 did not fix the issue either....sad to say.
Oh well. Anyone selling a Mac Pro?! :)
Pro Tools 2020
Mac Mojave
Mac Pro (canister type)
Twin Xeon processors
64GB DRAM
Apollo Quad + satellite
Multiple Enterprise class SSDs (mixed use endurance)
Solid State Logic Nucleus.
Old 01-08-2018, 01:36 PM
If you don't mind a cheesegrater take a look at what OWC has. I got my current system from them and made some of my own upgrades (ssd for system drive, etc.). Mine came with Sierra but it's easy enough to go to whatever OSX you want.
Jack
QAPLA!
Old 01-08-2018, 02:25 PM
Is the Nucleus only connected via Ethernet? I thought it was a USB piece and was going to ask if you killed the Power Management feature on the USB ports?
  #16
Old 01-08-2018, 02:32 PM
uptheoctave uptheoctave is offline
Nucleus connects via ethernet and USB.
USB is only for the keyboard emulation side of things.
Ethernet is for all of the controller functionality and, in the Nucleus 2, for Dante.
James Richmond
https://www.jamesrichmond.com
2019 Mac Pro, 2022 Mac Studio Ultra
Avid S6, HDX2, MTRX II, MTRX, DAD AX64, AX32, Focusrite Rednet PCIER, Trinnov MC8 Pro.
Studio: https://www.voltperoctave.com | Music: https://www.euclideancircuits.com
Latest Article: Auto-Bounce for Logic Pro
Affiliate Links:
Auto-Bounce by Tom Salta
Dreamhost Web Hosting
  #17
Old 07-06-2020, 05:22 PM
Ubafunksta Ubafunksta is offline
I have the same problem on OSX 10.15 and PT 2020.03
Any ideas?
  #18
Old 07-06-2020, 05:55 PM
This thread was from 4 years ago, I would hope SSL support got on top of this and would know what works.
  #19
Old 07-07-2020, 12:39 PM
Speaking to them - still an issue in my case.
  #20
Old 12-19-2020, 04:28 AM
Statick Statick is offline
I've been having this same issue on a mac with OSX 10.13.6 (High Sierra) since a recent PT update in the last month or so. Was working fine until the update, since then it's been connecting okay but "read only", in that I can move a fader on screen and a fader on the Nucleus will move, but touching any faders or buttons on the Nucleus has no effect
I've managed to sort this by going into network settings and changing IPv6 from auto to manual, and leaving the manual settings blank. I'm guessing PT is seeing the auto IPv6 setting and it's causing a problem somehow
SSL Nucleus - Pro Tools 11 I/O Settings TerryBarnett Pro Tools 11 4 06-29-2014 05:39 AM
Issues using Propellerhead Balance interface with Pro Tools 10 Ryley.Conroy Windows 4 03-19-2013 08:31 PM
Problem with ASIO4ALL using Nucleus and Pro Tools 9 gwaine Windows 0 11-07-2012 10:30 AM
Pro Tools 9 SSL Nucleus ibanezartist macOS 4 01-03-2012 08:51 AM
Ssl nucleus and pt9 chicken macOS 10 05-19-2011 07:04 AM
