Can't set audio drive to Record Mode - Please look!
HI Guys,
I know there are a few threads on this but I have searched and tried the fixes available--Please Digi Support can you cast an eye over this thread. I'm currently using a Digi003 Rack with PT 7.4 and Windows XP pro. When logging on under the Admin Account I have no issues at all with opening pro tools or anything recorded in the audio drive. I can also record no issues. When I log on under my user name I get an audio drive error:- http://i24.photobucket.com/albums/c42/Willo_1/AudioDriveError.jpg http://i24.photobucket.com/albums/c4.../Workspace.jpg I try to set the audio drive to record and it states it's not a valid audio drive??? Not sure what is going on. Cheers Willo |
Re: Can't set audio drive to Record Mode
Go to disk manager and make sure the disk is formatted "Basic".
Thank you for your reply,
I have been meaning to add to this as I have read a few fixes and all have been ticked off.
Cheers Willo |
Re: Can't set audio drive to Record Mode - Yes I've Searched :)
Bump....I have searched web and duc and tried all remedies.
Help......
It might be interesting to create a new user account and see if that changes anything. I beleive there actually may be a command line command to repair disk partitions (or ACL's), I've seen mention of it but don't remember the command or the variable. It may have been DTS the mentioned it though. I don't have a immediate answer to this one
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
Digidesign Support??????????
What are the read/write permissions set to for the drive? Right-click on drive and select Sharing and Security, then go to the Security tab and check the permissions for each type of user/account.
I am having the same issue. I've looked everywhere and can't figure it out. I just got a WD 500GB eSATA drive and the file system is FAT32. If I try to open a new file, I get its "formatted as a FAT volume", so I can't change the A or V to R. Am using this on a Vista system. I can pull up old projects, just can't open any new ones.....
Actually your problem is different Airborne.
FAT 32 is not supported in Vista Pro Tools. Your drive needs to be formatted NTFS. Backup your files and reformat the drive NTFS Basic. |
Force a drive to be an Audio Record Volume - Possible? | Qjimbo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 10-09-2010 03:41 PM |
Audio Effects not being Monitored in Record Mode | James and Julieah | Pro Tools M-Powered (Win) | 0 | 09-11-2009 01:11 AM |
PT 7.3 Can't audition searched audio in Digibase | Big World | Pro Tools TDM Systems (Mac) | 1 | 12-08-2006 11:56 AM |
Partitioning Audio Record Drive | brianjanthony | Pro Tools TDM Systems (Mac) | 6 | 06-14-2005 12:05 AM |
Can't record to my audio drive - HELP | tufness | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 09-03-2004 04:59 PM |
