HUI: nervous faders?
Has anyone else had this "problem"?
The faders on the HUI will randomly twitch during playback, i.e. a fader will jump up about an inch and return to its original position (within a split second). While this is not impacting my work in any way, it's kind of annoying. I figure there is some confusion of MIDI messages or something. The volume output of ProTools is not affected. |
Re: HUI: nervous faders?
Well, i have.
Sometimes, but not that often that it is that annoying. I use Midi translator II through a seperate port, i mean seperate from my timecode machine. |
Here is a old post describing how to adjust the sensitivity on the HUI-faders.
"I was able to use the sensitivity screws located on the underside of the console to help with my problem. There are two rows of screws. The row you need to work with is the row with the staggered screw. (The staggered screw is the 8th fader). Depending on which faders are fighting you can turn the screws counterclockwise to reduce the resistance on that channel. Be careful, because if you do it too much that fader will move when your finger even gets close to it without touching it. Good Luck [This message has been edited by blairl (edited January 04, 2000).]
Tom R. Andresen Norway |
Does OSX Lion make anyone nervous? | SixChurchStreet | macOS | 17 | 12-16-2010 05:22 PM |
Custom Faders moves position of all other faders!?! | freeBase | ICON & C|24 | 5 | 02-26-2009 06:44 PM |
Nervous about deleting unused regions | Brain Digger | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 05-16-2005 12:59 PM |
Nervous | doug kaufman | Pro Tools TDM Systems (Mac) | 0 | 04-22-2005 06:37 AM |
Nervous About Procontrol | nozza1 | ProControl, Control|24, Command|8 | 4 | 11-08-2001 12:29 AM |
