Keep getting blue screen of death
Almost every time I use Pro Tools (I have 9), I eventually get the BSOD. I can always tell when it's going to happen when this weird crackling sound appears while recording or during playback. Is this a driver issue? Should I reinstall Pro Tools? How do I resolve this?
Thanks. |
Re: Keep getting blue screen of death
Take a pic of the terminal stop screen AKA BSOD. All those numbers on the bottom? They are not gibberish but hexadecimal code that when punched into Google in many cases will take you to a MS KnowlageBase article and point out the specific causes of the issue. Also typing in the message such as IRQ_IS_LESS_THAN_EQUAL. Or BAD_POOL_CALLER.
My guess is bad memory or a driver issue.
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
To further sunburst's comment, try using a memory tester to verify your ram is good:http://www.memtest.org/
Joel
Jam Space: HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Home: Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Rig: Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM |
I use an MSI GE60 (laptop) with i7 core processor and 8gb of ram. I haven't been storing them to an external hard drive. I'll try and take a picture next time it happens.
Post a Sandra Report for a bit more detail. If you get a pic of the bsod when it happens, we can take number scheme from the crash and get a good idea what the problem is. The meaning of the code can vary a bit depending on your chipset ie. sandy bridge, ivy bridge etc. But as they are hinting, memory issues or bad overclocks are the typical cause.
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
SiSoftware Sandra
ID Host Name : Banner-MSI Workgroup : WORKGROUP Computer Model : MSI GE60 0NC/GE60 0ND Serial Number : FFFF**** Chassis : MSI Notebook Mainboard : MSI MS-16GA Serial Number : BSS-012******* BIOS : AMI (OEM) E16GAIMS.10F 12/18/2012 Intel vPro : 8.00.02.1410 Total Memory : 7.9GB DDR3 SO-DIMM Processors Processor : Intel(R) Core(TM) i7-3630QM CPU @ 2.40GHz (4C 8T 3.2GHz/3.4GHz, 3.2GHz IMC, 4x 256kB L2, 6MB L3) Socket/Slot : FC PGA988 Chipset Memory Controller : MSI Core (Ivy Bridge) Mobile DRAM Controller 100MHz, 8GB DDR3 SO-DIMM 1.6GHz 64-bit, Integrated Graphics Memory Module(s) Memory Module : Nanya NT8GC64B8HB0NS-DI 8GB DDR3 SO-DIMM PC3-12800S DDR3-1600 (11-11-11-29 5-40-13-6) Video System Monitor/Panel : LGD Generic PnP Monitor (1920x1080, LP156WF1-TLF3, 22.3") Video Adapter : Intel(R) HD Graphics 4000 (16 SM5.0 350MHz/1.15GHz, 2GB DDR3 1.6GHz 64-bit, Integrated Graphics) Graphics Processor OpenCL GP Processor : Intel(R) HD Graphics 4000 (16SP 16C 350MHz, 1.6GB DDR3 1.6GHz 64-bit, Integrated Graphics) OpenCL GP Processor : NVIDIA GeForce GTX 660M (384SP 2C 1.67GHz, 2GB 5GHz 128-bit) Compute Shader Processor : NVIDIA GeForce GTX 660M (384SP 1.67GHz, 2GB 5GHz 128-bit) Compute Shader Processor : NVIDIA GeForce GTX 660M (384SP 1.67GHz, 2GB 5GHz 128-bit) CUDA GP Processor : NVIDIA GeForce GTX 660M (384SP 2C 1.67GHz, 2GB 5GHz 128-bit) Storage Devices WDC WD7500BPVX-22JC3T0 (750.2GB, SATA600, 2.5", 5400rpm, 8MB Cache) : 699GB (C:) (D:) TSSTcorp CDDVDW SN-208DB (SATA150, DVD+-RW, CD-RW, 1MB Cache) : N/A (E:) Logical Storage Devices OS_Install (C:) : 412GB (NTFS) @ WDC WD7500BPVX-22JC3T0 (750.2GB, SATA600, 2.5", 5400rpm, 8MB Cache) Data (D:) : 275GB (NTFS) @ WDC WD7500BPVX-22JC3T0 (750.2GB, SATA600, 2.5", 5400rpm, 8MB Cache) BIOS_RVY : 12GB (NTFS) System : 100MB (NTFS) Optical Drive (E:) : N/A @ TSSTcorp CDDVDW SN-208DB (SATA150, DVD+-RW, CD-RW, 1MB Cache) Peripherals LPC Hub Controller 1 : MSI Panther Point LPC Controller Audio Device : MSI Panther Point High Definition Audio Controller Audio Codec : Realtek Semi High Definition Audio Disk Controller : MSI Panther Point Mobile 6 port SATA AHCI Controller Disk Controller : MSI PCIE CardReader USB Controller 1 : MSI Panther Point USB xHCI Host Controller USB Controller 2 : MSI Panther Point USB Enhanced Host Controller #2 USB Controller 3 : MSI Panther Point USB Enhanced Host Controller #1 SMBus/i2c Controller 1 : Intel ICH SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Network Adapter : Killer e2200 PCI-E Gigabit Ethernet Controller (NDIS 6.20) #5 (Ethernet) Wireless Adapter : Intel(R) Centrino(R) Wireless-N 135 (802.11g (ERP), AES-CCMP, 48Mbps) Power Management Battery No 1 : NEC PC-VP-BP77 48.84Wh/3.95Ah Operating System Windows System : Microsoft Windows 7 Home 6.01.7601 (Service Pack 1) Platform Compliance : x64 Windows Experience Index Current System : 5.1 Not sure which link to download for the Memtest. Thanks for all your replies/help so far, by the way. |
First off I see that you are using a 5400 rpm harddrive. That right there is not gonna work well as it needs to be 7200 rpm or more. Also you really need a separate recording drive for the audio from Pro Tools as recording to a 5400 rpm spinner aswell as using that drive for system OS will deffinately give you errors and issues and the more you record the worse it will get.
That drive is also a "blue" drive and considered a no no for use in recording especially Pro Tools. I don't know what others will say but this is a real problem. Chris
Problem !!! Problematik ! nicht gut
So if I buy an external 7200rpm hard drive and save all my Pro Tools sessions on that, the BSOD will stop appearing? I wish Avid had listed that in the system requirements. Anyone have any recommendations on Pro Tools-compatible external hard drives?
Win 7 blue screen of death | scubapig | Pro Tools 9 | 2 | 11-25-2010 08:00 AM |
Blue Screen of Death PT LE 8 | MotifMan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 12-21-2008 07:07 PM |
Blue screen of death *S!@p&***!! | dumdrummer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-23-2007 11:16 AM |
Blue Screen of Death | ctsrar | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 07-20-2002 11:50 PM |
Blue screen of death... | Alex TCH | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 08-06-2000 03:20 AM |
