Old 06-26-2013, 11:03 AM
WKG WKG is offline
Default CPU usage meter/buffer settings...
I am seeing a significant spiking in the CPU usage meter at idle/playback on lower buffer settings vs higher. I've seen a few posts indicating some are seeing no difference in the CPU meter at idle/playback regardless of the buffer setting.
My understanding of the new input/output buffering is that the input is set via the Playback Engine/Setup App and output is automatically set depending on the session sample rate, in this case 44.1.
I would expect to see significant CPU usage at a 64 buffer when tracking but on playback or at idle shouldn't it reflect lower CPU per the higher auto setting for output? It drops significantly if the Ignore Errors During Playback/Record box is ticked which looks like the Hardware buffer setting is locked to both input and output.
Anybody else seeing this?
I7-4930K, X79-Deluxe, 2133 32 GB,
GT640, 512GB 860 Pro, 1TB Evo, WDB 2TB X2,
Win 10 Pro, PT Ultimate 2019.6 REAPER 6.02
RME, Daking, Heritage, ISA, Sytek
ASUS N71Jq i7 940xm 8GB DDR3
PTHD 12.1 REAPER - Win 10 HP
Old 06-26-2013, 02:40 PM
WKG WKG is offline
Default Re: CPU usage meter/buffer settings...
Am I the only one experiencing this? Seems odd given the new buffer system...
Old 06-26-2013, 05:57 PM
Bharath's Avatar
Bharath Bharath is offline
One thing that is not very obvious is that the device is still operating at your chosen hardware buffer size. Spiky meters usually indicates underlying issues (mostly DPC latency) that could be choking AAE <--> Device data transfers.
:: Bharath
Pro Tools Software Team
Old 06-26-2013, 07:19 PM
mykhal c's Avatar
mykhal c mykhal c is offline
you might have checked this already but make sure you have 'run as admin' checked for PT. i've seen the playback setting panel/settings have issues when this is not checked...especially with ASIO drivers. hope that helps.
bassist...deep pocketz anyone???!!!
The Basschakra Lucid Soul Trip
i7 Builds - Specs and Results
HDNative | Omni | i7-3930K OC'd 4.0GHZ |
ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff
Old 06-26-2013, 08:55 PM
WKG WKG is offline
It the total CPU meter that bounces around a lot, the core meters are pretty stable if higher than expected given an idle state with no input. I don't get any errors, clicks or dropouts at all. Interesting though, if the new output buffer is automatically set by PT but still subject to the device settings then what is the benefit?
Thanks for the tip. I thought I had that checked but did not. Seems like it may have helped a bit.
Old 06-26-2013, 09:15 PM
kelco83's Avatar
kelco83 kelco83 is offline
I had a nasty pop sound through my monitors, turned out to be an IRQ issue. I wouldn't say conflict, as theyre supposed to share, but apparently, my interface refuses to.
latencymon and dpclat were very happy once that IRQ issue was addressed.
Intel 4770K Hackintosh 16GB 128 SSD 770 GTX PT10 11 rack
Mac mini ivy bridge i5, apogee quartet, PT10, 11 rack
Old 06-27-2013, 12:51 AM
Holly73 Holly73 is offline
Could you shed some more light on how this input buffer/output buffer thing works?
I don't get it somehow. Avid ads said it is the input buffer that is set in the playback engine. But in the Reference Guide it sounds the same like in prior versions. And also in tests Russ did over at pro-tools-expert.com the performance changed when changing the buffer. But if it is an input buffer, there should be no changes when not recording, or am I wrong?
What you mean by saying "the device is still operating at your chosen hardware buffer size"? How PT then does the output buffering?
Btw, I also have these spiking meters, but I'm on a Mac. They are at around 20% average but sometimes jump to 100% and then I get -6101 and -9173 errors.
 MBPr 15" (Mid 2015) i7, PT12.4, Studio One 3, UA Apollo Quad Firewire
Old 06-27-2013, 03:02 PM
WKG WKG is offline
I am curious about this as well.
Maybe a PT 11 Sensei can shed some light on this?
Bharath?
Old 06-28-2013, 05:03 PM
WKG WKG is offline
Bueller...?
Old 06-29-2013, 08:35 PM
WKG WKG is offline
Beavis...?
buffer settings in PT11 vs cpu usage musicman691 Pro Tools 11 0 10-11-2013 05:23 AM
System Usage Meter crazedbassist440 Pro Tools M-Powered (Mac) 0 01-05-2010 10:24 PM
The system usage meter... AdamPT8 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 01-04-2010 08:48 AM
Buffer errors with the CPU usage meter at less than 25% johnjm22 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 08-09-2007 11:55 AM
system usage meter, what does the red mean gargigs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-07-2006 11:52 PM
