Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools SE and Essential (Win)
Old 09-12-2011, 06:34 AM
Tswdkc87 Tswdkc87 is offline
Exclamation More Pro Tools SE White Noise Issues
Hi there.
Over the past month or so I've been talking with someone on the M-Audio forums on ways to result and intermittent popping noise while using Pro Tools SE.
After completing absolutely all of the system optimizations, I went out and bought a 1 terabyte external hard drive to record onto, leaving Pro Tools on my C drive which still has 5.3G of free space.
Nothing I've done has solved this issue, and it seems to be getting worse. Sometimes the popping starts when Pro Tools SE is loading, sometimes it happens on playback, and it always happens while recording.
When I restart my computer it subsides for about 5 minutes or so but then starts acting up again.
Here are some system specs that I'm running:
Windows 7 Premium SP1
AMD Phenom 9750 Quad-Core Processor 2.40 GHz
8.00 GB RAM (plus 1 TB of external hard disk space completely empty)
64-bit OS
Computer is an HP
As you can see my system is MORE than capable of running this program.
Please do not link me the optimization thread. I've already done them all and it solved nothing. I'm looking for some real answers to this program-breaking issue. If anyone has suggestions or updates on this please leave a response.
Also, Pro Tools SE doesn't have a "Setup" link at the top, therefor I'm unable to reduce the buffer rate. Those options are only in the more advanced versions of Pro Tools.
EDIT: I also want to point out that when recording vocals onto Tracktion there is no static at all. This is 100% within Pro Tools.
Last edited by Tswdkc87; 09-12-2011 at 07:15 AM. Reason: Forgot to put some important information in.
Old 09-12-2011, 08:14 AM
vince t vince t is offline
Default Re: More Pro Tools SE White Noise Issues
Hi Tsw,
What interface are you using? What version of SE are you running? I can't seem to locate any other posts from you with this info.
you can private message me if you like with a full bug report..if you open the M-audio control panel for the interface you can change the buffer size, look under programs for an M-Audio folder.
Thanks,
Vince
Old 09-12-2011, 04:39 PM
M-Audio MobilePre 1.0.4
When I open up Pro Tools SE and check for updates it says there are none. So I'm using whichever version is the latest.
Also, how do I get a full bug report?
Old 09-13-2011, 10:32 PM
Lol. I was directed here by the M-Audio forums to further solve this issue, and I can't even get a response.
Simple question. Since M-Audio interfaces well with Tracktion, give me one good reason I should buy the full version of Pro Tools. Just one reason. Simple question, no math or science involved.
White Noise, distortion, pops, loud noise in Pro tools 9 and mbox mini Bigpit Windows 1 09-09-2013 09:26 AM
SPDIF white noise issues from preamp... smc108 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 05-17-2010 07:16 PM
Any progress on the 8.03 white noise issues? Phil O'Keefe Pro Tools TDM Systems (Win) 2 03-04-2010 10:31 PM
Has there been any news on the 8.03 white noise issues? Phil O'Keefe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-04-2010 07:22 PM
WHITE NOISE mBox issues Bouncing only fix RESET? CafeCinema 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-20-2004 09:41 PM
