Old 07-23-2010, 02:16 PM
Meads Meads is offline
Default Crashes when opening Session containing Plugins
Hi there,
I just got a PT LE 8.0.4 with CPT, and I'm using Win 7 64Bit.
I also got the Gold Bundle from Waves (V7), and my problem is a real pain in the neck. Whenever I try to open a recently saved session, that contains plugins (no matter which or how many), Pro Tools crashes at the "restoring tracks" message, leaving no error message, just freezing.
But I can't lay my hand on it. Sometimes I open the same session several times without problems. And then one time it freezes and won't open ever again, always freezing at the same point.
I already tried creating a new session and importing the tracks from the freezing session. Same here, always freezing at "restoring track", but it isn't always the same track. But always a track with plugins inserted.
So the source cannot be a particular plugin, but the principle of an existing plugin on a random track. It's really weird.
Has anyone any idea? It's impossible to work with PT that way.
Old 07-23-2010, 02:19 PM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
Default Re: Crashes when opening Session containing Plugins
Hold shift & then open the session while holding it; activate the plugs 1 by 1 til u find the culprit as it is a plug or combination of them...
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
Old 07-23-2010, 02:26 PM
That was quick, thanks!
Okay, I tried that, and a session, that always froze opened fine. So I activated all plugins one by one, and there was no error whatsoever. I could playback fine, everything worked.
Then I saved it, closed and tried to reopen it - again the freeze on "restoring tracks".
iMac Pro
- MacOS 10.14.6
- Pro Tools U HDN 2019.6
- Avid HD Omni + HD I/O 8x8x8
- C|24 | S3 | Dock
Old 07-23-2010, 02:31 PM
that sucks; hav u trash the Databases folder? that may not be the end all solution but see if that can help any...
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
Old 07-23-2010, 02:35 PM
Would be astounding if that helped, since I just installed PT yesterday. But being short of other clues, I'll give it a try.
iMac Pro
- MacOS 10.14.6
- C|24 | S3 | Dock
Old 07-23-2010, 02:41 PM
Hm, nope. Didn't do the trick.
Any other thoughts? Pretty please...
iMac Pro
- MacOS 10.14.6
- C|24 | S3 | Dock
Old 07-23-2010, 03:39 PM
How big is the session?
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
Old 07-23-2010, 03:52 PM
Not huge. It contains 13 audio tracks and 5 aux tracks and about 20 plugins.
iMac Pro
- MacOS 10.14.6
- C|24 | S3 | Dock
Old 07-23-2010, 07:00 PM
U may wanna go ahead & post a Tamara Report so we can take a look @ ur rig; I see its a C2D (not sure about ur chipset) but that along with PT8 & W7, U could be gettin memory|processor hangups on loading the plugs epspecially if there are other things runnin in the background which I'm quite sure there is being thatz a laptop u hav this on...
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
Old 07-24-2010, 02:40 AM
I'm not sure, what "Tamara" is -sorry.
I'll post a sandra report, hope that will help.
This particular laptop I have is mentioned on the digidesign page as "certified for PT 7.4". That's why I bought that one, and no other. It would be kinda annoying, if you needed a new workstation everytime you upgrade your PT. Oh boy...
I'm not running any other things while working with PT. Not intentionally that is, maybe there are a few processes windows starts itself, that I do not know of.
However, here is my sandra report:
SiSoftware Sandra
System
Modell : HP HP Compaq nw8440 (RY852EP#AK8)
Arbeitsgruppe : WORKGROUP
Hostname : X-Notebook
Benutzer : X
Prozessor
Modell : Intel(R) Core(TM)2 CPU T7200 @ 2.00GHz
Geschwindigkeit : 2GHz
Kerne pro Prozessor : 2 Einheit(en)
Threads pro Kern : 1 Einheit(en)
Typ : Mobile, Dual-Core
Interner Datencache : 2x 32kB, Synchron, Write-Thru, 8-weg Satz, 64 Byte Zeilengröße
L2 Onboard Cache : 4MB, ECC, Synchron, ATC, 16-weg Satz, 64 Byte Zeilengröße, 2 geteilte Threads
System
Platform Compliance : Intel Centrino
Mainboard : HP 30A3
System BIOS : HP 68YVD Ver. F.15 11/23/2007
Bus(se) : X-Bus PCI PCIe IMB PCMCIA CardBus USB FireWire/1394
MP Unterstützung : Nein
MP APIC : Ja
Gesamtspeicher : 3.38GB DDR2 SO-DIMM
Chipsatz
Modell : HP Compaq nw8440
Front Side Bus Geschwindigkeit : 4x 166MHz (664MHz)
Gesamtspeicher : 4GB DDR2 SO-DIMM
Speicherbusgeschwindigkeit : 2x 332MHz (664MHz)
Speichermodul(e)
Speichermodul : Hynix (Hyundai) HYMP325S64AMP8-Y5 2GB DDR2 SO-DIMM PC2-5300U DDR2-666
Speichermodul : Samsung M4 70T5669AZ0-CE6 2GB DDR2 SO-DIMM PC2-5300U DDR2-666
Grafiksystem
Grafikkarte : ATI Mobility Radeon X1600 (PS3.0, VS3.0 391MHz, 256MB 252MHz, PCIe 1.00 x16)
Grafikprozessor
Physische Speichergeräte
WDC WD5000BEVT-00ZAT0 (500.1GB, SATA300, 2.5", 5400rpm, NCQ, 8MB Cache) : 466GB (C:) (D:) (E:) (F:)
HL-DT-ST DVDRAM GSA-4084N (ATAPI, DVD+-RW, CD-RW, 2MB Cache) : k.A. (G:)
Logischer Speichergeräte
Festplatte (D:) : 30GB (NTFS) @ WDC WD5000BEVT-00ZAT0 (500.1GB, SATA300, 2.5", 5400rpm, NCQ, 8MB Cache)
Windows 7 (C:) : 68GB (NTFS) @ WDC WD5000BEVT-00ZAT0 (500.1GB, SATA300, 2.5", 5400rpm, NCQ, 8MB Cache)
Projekte (E:) : 293GB (NTFS) @ WDC WD5000BEVT-00ZAT0 (500.1GB, SATA300, 2.5", 5400rpm, NCQ, 8MB Cache)
Kram (F:) : 74GB (NTFS) @ WDC WD5000BEVT-00ZAT0 (500.1GB, SATA300, 2.5", 5400rpm, NCQ, 8MB Cache)
CD-ROM/DVD (G:) : k.A. @ HL-DT-ST DVDRAM GSA-4084N (ATAPI, DVD+-RW, CD-RW, 2MB Cache)
Peripherie
LPC Hub Controller 1 : HP Compaq nw8440
LPC Legacy Controller 1 : T1 26-00
Audio Gerät : HP Compaq nw8440
Audio Codec : Analog Devices AD1981HD sound chip
Audio Codec : Lucent/Agere Systems (Was: AT&T MicroElectronics) TOSHIBA Software Modem
Serielle Port(s) : 3
Parallel-Port(s) : 1
Laufwerkscontroller : HP 82801GBM/GHM (ICH7-M) Serial ATA Storage Controller
Laufwerkscontroller : HP Compaq nw8440
USB Controller 1 : HP Compaq nw8440
USB Controller 2 : HP Compaq nw8440
USB Controller 3 : HP Compaq nw8440
USB Controller 4 : HP Compaq nw8440
USB Controller 5 : HP Compaq nw8440
FireWire/1394 Controller 1 : HP Compaq nw8440
CardBus/PCMCIA Controller 1 : 64512 PCIxx12 Cardbus Controller
Drucker- und Faxgeräte
Drucker : Microsoft XPS Document Writer (600x600, Farbwiedergabe)
Drucker : Samsung CLX-3170 Series (600x600, USB, Farbwiedergabe)
Netzwerkdienste
Netzwerkadapter : Broadcom NetXtreme-Gigabit-Ethernet
Wireless-Adapter 1 : Intel(R) PRO/Wireless 3945ABG-Netzwerkverbindung (802.11g (ERP), TKIP, 54Mbps)
Energieverwaltung
Stromnetzstatus : Angeschlossen
Batterie Nr. 1 : 95%
Betriebssystem
Windowssystem : Microsoft Windows 7 Ultimate 6.01.7600
Platform Compliance : x64
iMac Pro
- MacOS 10.14.6
- C|24 | S3 | Dock
random crashes when opening or changing plugins swethington 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-21-2008 05:15 AM
Pro Tools crashes when opening (mounting) plugins - Help! jedhiggs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-01-2007 12:55 AM
PT LE crashes upon opening session London 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-20-2006 06:39 AM
PT crashes when opening session Eddie D 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 08-17-2005 11:16 PM
ProTools LE 6.4 crashes when opening a session olguitar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-07-2004 04:13 PM
