Old 05-16-2010, 05:30 PM
smc108 smc108 is offline
Angry SPDIF white noise issues from preamp...
I recently purchased the ART DMPA II (digital) preamp that I'm using with my Presonus Digimax FS through the 002. I purchased the ART to allow 18 inputs when tracking. The Digimax is connected via adat and ART via spdif. The problem i'm having is that there is BAD white noise coming through the track enabled from the ART preamp. I'm clocking through ADAT optical (the DIGIMAX). I don't think it's a clocking issue becuase there are no popping noises. Both Digimax and ART are set to 48k 24 bit. I have also tried in 44.1 with the same issues. ANY SUGGESTIONS? PLEASE HELPPP!
Old 05-16-2010, 06:06 PM
Top Jimmy's Avatar
Default Re: SPDIF white noise issues from preamp...
The ART also needs to be clock synced with the master (Digimax). Get a word clock cable (BNC) and connect from the word out of the Digimax to the word in on the ART. Put the ART into word clock sync. problem solved.
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Mojave 10.14.4.
Pro Tools HD Native 2020.3, Focusrite Red 8Pre, Mbox 3 (Mac)
Pro Tools 11.3.2, Mbox2 (Win 7)
Old 05-16-2010, 07:59 PM
Sorry, i forgot to add that I do have a BNC cable from the DIGIMAX to the ART.... still same issue. What do you mean "Put the ART into word clock sync?" In PT setup, i have optical/adat chosen. I'm running 7.3 LE.
Old 05-16-2010, 08:20 PM
Top Jimmy's Avatar
See the Sample Rate/Dither knob? Turn it to Ext/24.
James Cadwallader
Old 05-17-2010, 07:16 PM
Didn't work...Still same issues! URRRGGGG!
spdif issue with ART DMPA II - white noise smc108 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 07-14-2010 08:07 AM
Any progress on the 8.03 white noise issues? Phil O'Keefe Pro Tools TDM Systems (Win) 2 03-04-2010 10:31 PM
Has there been any news on the 8.03 white noise issues? Phil O'Keefe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-04-2010 07:22 PM
HELP!! White Noise and broken sound with SPDIF and Mbox2 keylowd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-18-2007 06:48 AM
white noise coming from mbox when spdif selected djaikon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 06-23-2004 09:34 AM
