Old 11-30-2007, 09:07 AM
shoog shoog is offline
Default how to assign a plugin to a midi track
newbie question here:
- I have a m-audio keystation 88 usb
and
- a roland td 3
I want to pilot wrapped vsti's such as lounge lizard with the maudio,
and I want to pilot drumkit from hell superior with the roland td3
please explain me how to, I can assign plugs to audio tracks but can't find the way to do with midi tracks.
Old 11-30-2007, 03:03 PM
spkguitar's Avatar
Default Re: how to assign a plugin to a midi track
Wow.
Have you read the manuals?
Virtual instrument plugins cannot be used directly on MIDI tracks. Typically, when using virtual instrument plugins, they are inserted on Instrument or aux tracks. WHen inserted on Instrument tracks, the instrument track records the MIDI data, and then passes audio from the plugin through the track. The same can be done with both a MIDI track and an aux track.
You would really benefit from reading chapter 19 in the Pro Tools Reference Guide. It will go into detail about what you need to do, how to configure everything, what menus to select from, etc. It even includes phot references for your convenience.
As for the plugins:
Lounge Lizard is RTAS compatible; there is no reason to wrap it.
Old 12-01-2007, 12:03 AM
thank you for your reply. I bought my digi 002 used, no manual. do you know where I can download the manual in french or english?
Old 12-01-2007, 07:50 AM
spkguitar's Avatar
The manual (the "Pro Tools Reference Guide") is installed with the software as a PDF...
You can also download all of the manuals ("Tech Docs") from the product's support page.
If you already had Lounge Lizard before you installed Pro Tools, you may need to run it's installer again to install the RTAS compatibility portion, or even get an update from the manufacturer's website.
You may also benefit from my tutorial pages on www.ptnewbie.com
Could not assign plugin aux output on the same track as the plugin... shotgunndunn macOS 1 11-07-2012 09:05 AM
How to assign a fader to automate a plugin parameter?? teacherman ICON & C|24 5 03-04-2009 11:59 AM
How to assign MIDI CC to plugin parameters if no MIDI Learn? Mitch Manger 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-25-2007 11:10 AM
Assign multiple outputs from a Midi Track Antonio Tarantino 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-11-2003 05:17 PM
how do u assign midi conrtoller to plugin parameter? hokuspocus Pro Tools TDM Systems (Mac) 2 03-20-2002 09:22 AM
