Old 11-17-2005, 03:11 PM
Travis_BCN Travis_BCN is offline
Default Can\'t use MIDI controllers with Mbox 2
Hi there.
I just get a new Mbox 2 today, installed PT LE 6.8.1 and everything was OK. But in the MIDI Controllers menu, in Peripherals, something is wrong: whatever the type of controller i choose, the send/receive boxes remain inactive!
i have a BCF2000, using HUI protocol, and it worked ok in PT LE 6.9.2 with an original Mbox. I use 10.4.2, and i installed 6.8.1 without removing 6.9.2.
help..
Thanx.
Old 11-17-2005, 05:18 PM
Digi Engineering Digi Engineering is offline
Default Re: Can\'t use MIDI controllers with Mbox 2
If it's there, remove the following component: /Library/Audio/MIDI_Drivers/DigiDioMidiDriver.plugin
It's the 002 midi driver so you don't need it with the Mbox 2.
-digi-eng
Old 11-18-2005, 11:21 AM
it was there.
I removed it, re-boot, and failure again.
could i try something else?
Thanx.
(edit: ..and if I leave the Peripherals menu by clicking OK, PT crashes. )
Old 11-19-2005, 04:35 AM
A2D D2A A2D D2A is offline
Hi there.
I would start right there and do a clean install.
Uninstall what there and start from scratch with 6.8.1.
Midi Predifined options in Peripherals\Midi Controllers menu RuffinMedia macOS 3 03-04-2015 04:54 PM
MIDI Virtual Ports not showing up in MIDI Controllers (8.0.5) emiliojazz Pro Tools M-Powered (Mac) 0 02-18-2013 12:03 PM
Midi Controllers - Midi Port Assignment eneezy1 Pro Tools M-Powered (Mac) 1 08-15-2012 08:44 PM
Midi Controllers - Midi Port Assignment eneezy1 macOS 4 07-30-2012 02:40 PM
Need advice! Mbox 2 mini with midi controllers TrustoneR 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-09-2007 06:20 AM
