Old 10-22-2005, 03:56 PM
Default MIDI Playback notes cutting out
Hello to All
Ummm... just finished recording an arrangement to MIDI. This data has been stored, shown by MIDI notes on the piano-roll and the MIDI Audio Regions List. The recording setup is Stereo AUX with insert, MIDI Track assigned to channel, this has not changed. Disabled record mode, hit Space bar and the MIDI meter indicates playback is fine, consistent and correct to the performance data stored. Problem is that the AUX and Master are not receiving this information or should I say they are receiving versions of it, they are not receiving the complete version. All I'm hearing is this cutting out, stop start version, cutting out differently each playback time.
I'm scratching my head over this one.
Any thoughts?
Aaron Mulqueen - 001 HD Native
Old 10-22-2005, 07:15 PM
Default Re: MIDI Playback notes cutting out
So, I thought try re-recording the arrangement. Setup the same as before, everything the same.
...And lo and behold, not a problem. Played back the way it should.
Got me
Old 10-22-2005, 08:45 PM
ScorchedEarth ScorchedEarth is offline
If that ever happens again, check the polyphony settings on your Synth/Sampletank/whatever software you are using. If the settings are too low, you might get symptoms like yours.
Old 10-22-2005, 09:06 PM
Yeh, Hi
I checked to see if my Moog Modular has such a setting and I'm not to sure about that one.
You've come across this yourself?
Midi Notes cutting off when recorded mpeddle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-22-2015 02:05 PM
Midi notes cutting out when triggering plug-ins from Pro Tools/sequencing on MPC Refresh Pro Tools TDM Systems (Mac) 7 04-11-2012 05:56 PM
Cutting tails of midi notes Pieterrr macOS 12 03-01-2012 02:31 AM
notes cutting out only well recording.... CrAkD MIDI 0 07-15-2009 01:37 PM
Quantize is cutting notes short megalaser Pro Tools M-Powered (Mac) 3 12-25-2007 07:58 AM
