Old 07-22-2005, 09:17 AM
jimlongo's Avatar
jimlongo jimlongo is offline
Default 962cs2 Core audio and QuickTime - FIXED
QT playback is not working properly with the new CADs. First playback is fine then the second file will not register in the QTPlayer timeline and will stop after a few seconds.
noise | jimlongo
Old 07-22-2005, 10:03 AM
Digi Engineering Digi Engineering is offline
Default Re: 962cs2 Core audio and QuickTime
That sounds like the exact symptom that we just fixed in 6.9.2cs2. Do a "Get Info" on the following component:
/Library/Audio/Plug-Ins/HAL/Digidesign_CoreAudio.plugin
Is it version 6.9.2cs2?
Thanks,
Digi-Eng
Old 07-22-2005, 11:20 AM
jimlongo's Avatar
No it's still 6.9.2
jim
noise | jimlongo
Old 07-22-2005, 11:55 AM
studiojimi's Avatar
studiojimi studiojimi is offline
With the just released CADs when I play a sound file in QuickTime the first instance will play fine. Any subsequent items played back will not register in the QuickTime Player timeline and will cease playback after about 2 seconds.
Quit and relaunch QuickTime and the first file will always playback correctly the second will abort.
10.4.2/QT7.0.1/6.9.2cs2
make sure those subsequent files have the latest quicktime info attached to them thru apple "I"
not the old quicktime from being cloned in to your new hard drive partition
CAZADOR RECORDING
PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2
With GOD as my partner. . . I need to make my plans LARGER.
Old 07-22-2005, 03:17 PM
Try quitting all apps then re-running the installer. If you still see version 6.9.2 of the "Digidesign CoreAudio.plugin" component, then trash it (or save it somewhere else), and re-run the installer. In the meantime we're looking into the problem.
Thanks,
Digi-Eng
Old 07-22-2005, 04:05 PM
jimlongo's Avatar
Thanks that did it. It's possible I got lost following your links and downloaded the wrong installer.
noise | jimlongo
QuickTime and Core Audio p0rk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-30-2008 08:30 PM
Quicktime 7.5 and Core Audio Driver 2hands 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-08-2008 08:54 AM
once again: latest Quicktime & Core Audio 7.3 cs1? tokyofan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-07-2008 02:07 PM
Core audio and Quicktime 7 sricabla 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-24-2006 12:15 AM
Will Panther Core Audio get fixed as well? brianjanthony Pro Tools TDM Systems (Mac) 0 07-21-2005 07:16 PM
