Old 04-23-2005, 06:38 AM
studiojimi's Avatar
studiojimi studiojimi is offline
Default PREFS CRASH IN HD and OS (i think)
i'm not sure what caused this
but after failing mutiple time to be able to run a suckjsessful drive utility on a clients new 120 seagate
the next time i use PT the audio sweet prefs were down and most like the my entire PT prefs were crashed.
and now i'm suspicious of the OS prefs being corrupted somehow as the screen save still says it is off but it comes on after the computer has been idle.
does this sound familiare to some of you?
what did you do about it?
CAZADOR RECORDING
PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2
With GOD as my partner. . . I need to make my plans LARGER.
Old 04-23-2005, 06:45 AM
ruudman2003 ruudman2003 is offline
Default Re: PREFS CRASH IN HD and OS (i think)
If you're using 6.9, do you have journaling enabled on all drives?
ruudman
Old 04-23-2005, 09:02 PM
studiojimi's Avatar
i'm using 6.7 and i thought digi tech supplort told me no journaling?
CAZADOR RECORDING
Old 04-25-2005, 09:01 AM
DigiTechSupt's Avatar
Please follow the 'General Troubleshooting' steps in the sticky at the top of this forum.
Let us know if you are still having problems after going through those steps.
Avid Audio Tech Support
Support FAQ
Crash crash crash crash crashhhhh crahshrbnjfgeviufdbldfgvjndgokhng FuneralMusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 27 11-16-2009 12:02 AM
DAE Prefs causing Pro Tools 7.4 to crash on boot up Dustin Mosley Pro Tools TDM Systems (Mac) 3 11-13-2007 10:45 AM
Crash Crash Crash Live 6 Pro Tools Rewire TimmyP 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-12-2007 11:26 AM
No Sound-help!! After deleting Digisetup, PT prefs and DAE prefs bigthinka9 Pro Tools TDM Systems (Mac) 6 10-24-2002 07:41 AM
Installed 32track le version, won't run with Reaktor crash crash crash Christian 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-02-2002 11:05 AM
