Old 01-07-2005, 11:34 PM
WizDoomBorn WizDoomBorn is offline
Default Random pops, crackle, and clips. very annoying
For the past 3 or 4 months now when ever I consolidate, or process a track with an audio suite plugin, I get random clicks in the track. I can undo it, and redo the process and get the same type of clicks randomly in other areas. It doesnt seem to be dependent on parts of a track where there is audio, silent areas can experience these clicks as well. This has been very annoying, because i process and print to disk alot to save up cpu for other plug ins. I also like to consolidate all the tracks when done with a mix to have them uniform, and to also discard the unused audio files. So if anyone has any suggestions, please let me know something.
Also, I have already played around with the hardware buffer and dae playback buffer, and every variation of settings has resulted in the same thing.
Using PT LE 6.4cs9, OS X 10.3.7 and a 001
Power Mac G4 800Mhz
Digi 001
PTLE 6.4
Old 01-08-2005, 01:13 AM
Tubz Tubz is offline
Default Re: Random pops, crackle, and clips. very annoying
In preferences/processing, there you can raise the audiosuite buffersize. Try it and see if it helps.
BR Tubz
Old 01-08-2005, 06:44 AM
kite kite is offline
Is the 001 actually approved to run with OSX 10.3.7 ??? You also don't say if you have an external or additiional drive for recording-
www.kitestudio.co.uk
Mac Pro
Snow Leopard
003 & Midas Venice desk
Mindprint DTC
Soundelux U99
Drawmer M-Clock
Old 01-08-2005, 07:33 AM
I'm not sure if OS X 10.3.7 is approved to run with the 001. I should have looked into that before i updated, that could be an issue, but i believe this was happening when i was using 10.3.5 as well. And, yes i do have a seperate HD for audio, two seperate ones actually, anyone else ran into this and figured out how to fix it. i'm going to try what you suggested tubz and i'll let you know if it works...
Power Mac G4 800Mhz
Digi 001
PTLE 6.4
C24- Phantom Power causes crackle and pops GreenDC ICON & C|24 4 10-21-2010 06:08 PM
random clips when playing back/bouncing...help! goodbyeboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 09-14-2007 09:16 PM
Crackle and Pops D-MACK 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-29-2007 05:33 PM
Guitar Crackle and Pops? Punx Tips & Tricks 3 04-07-2003 02:40 PM
Hideous random crackle on playback!! chrisk Pro Tools TDM Systems (Mac) 3 10-19-1999 09:22 AM
