Old 02-05-2017, 10:35 PM
Imagine Imagine is offline
Default Is there a work-around re: Midi Merge Sustain bug?
Has anyone figured out a way to make this work aside from turning Midi Merge OFF?
Dean
Old 02-06-2017, 05:26 AM
Panacci Panacci is offline
Default Re: Is there a work-around re: Midi Merge Sustain bug?
I have a second track , duplicated from the original below it. I start with no midi info copied from the top one. I record from one to the other then when my track is done I combine them to make one. Careful of notes hanging over when you combine them . OR record in Logic, Cubase or I use DP then import into PT
Old 02-24-2017, 02:16 PM
spenner spenner is offline
I love Pro Tools, especially for mixing, but this bug is the main reason why I stopped upgrading at PT 9 Native and instead upgraded from Cubase 5 (that hadn't been used in years) to Cubase Pro 8 and now 9. Forget new features... I'm not upgrading anymore, and paying a yearly subscription, if the basics don't work.
Did a search and came across this thread. Just wanted to check back on the forum to see if 3 whole versions later it's fixed... Looks like it's not.
Old 02-24-2017, 03:49 PM
Which version of PT exactly? I just installed the newest 12.7.1 release and it appears to be working okay here(was messed up with the last version I had) My temp solution was to just show the sustain lane and fix it with the mouse after the pass(not elegant, but it did work)
Old 02-27-2017, 03:33 AM
Thanks Dave. I stop upgrading at PT 9; the bug exists in every version of 9 for me. Thread search results, including this one, show that it still exist in 10, 11 and 12.
Is there a trial version of latest version of PT native (search doesn't find one)? My work includes ballads across several genres where sustain pedal is used heavily, so I would like to test. Or can others, including OP, confirm with Dave that the bug is gone in 12.7.1; I don't see it as a fix on the release notes.
Old 02-27-2017, 03:55 AM
Stig Eliassen's Avatar
I just did a slow grand piano recording with MIDI Merge enabled, and couldn't make this bug appear. Recorded about 2 minutes without issues. Too early to tell if Avid squashed it, but the bug would definitely had happened in 12.5.2.
Problem with MIDI Merge on - sustain events ChrisSimon MIDI 13 10-18-2017 02:57 PM
Please fix midi merge sustain pedal!!! Mr.O Pro Tools 11 14 10-23-2016 12:23 AM
Will an external sustain pedal work with midi? CPG MIDI 2 12-13-2011 07:47 AM
MIDI merge doesnt work in ProTools LE 7.4 chrisdee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-22-2007 03:27 PM
