iOS Drum Machine app
I will be playing the acoustic piano on a gig and simply want to bring my iOS device to plug into the system for drum grooves as needed.
Is there a drum machine iOS app that would allow we to set grooves then seamlessly switch back and for between songs with different tempos? Thanks |
Re: iOS Drum Machine app
I've got a few - my 'plan' was/is to program accompaniment for different songs ... but I never get there! However, several are more than capable in this regard so you may want to check out a few Youtube videos to see what suits you e.g. different input methods. If you just want a nice click track, without programming fills, etc., this is easy too. :)
* Korg iElectribe / Fingerlab DM1 / Funkbox - typical step sequencer input, lots of kits/sounds possible and some also have pads/effects (DM1 probably the most flexible) * Native Instruments iMaschine - pads * Impaktor - place your iPhone/iPad e.g. on a table and 'play the table' * Drumjam - add percussion instruments and vary complexity/rhythm to find something you like You could also use apps like Garageband (includes a drummer + much more) and if compatible with Audiobus, you can pass audio from one app through another (recording, effects, etc.) :) |
Thanks for the reply. I checked out the apps you mentioned and like them. I ended up going with iMPC for iPhone, which was also recommended. It is the perfect app for what I need performance wise, and all I need to bring is my iPhone! Today the singer and I rehearsed the song list with the iMPC app. Four songs, zero problems from the app.
Good - I have iMPC too ... it was in another folder and I forgot to mention it. Whilst it's probably useful to learn one well by using regularly, these apps are generally so cheap that it's fun tho see where new ones take you creatively. Others worth checking out include Propellerhead Figure (recently free), Triqtraq, Korg synths, Loopy (looper) and Samplr. If you prefer to pre-record backing tracks, Auria would be more familiar to a Pro Tools user than Garageband (but really needs a recent iPad). Hope this helps in case your tempted to dig deeper on iOS!
Drum Machine | evankertman | macOS | 1 | 01-09-2012 06:13 PM |
dr3 drum machine | anthony brown | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 05-23-2006 10:05 AM |
best drum machine/drum software | robotman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 24 | 07-09-2005 12:09 PM |
Drum Machine or Drum Software | pacodub | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-23-2005 11:29 AM |
Making Separate Drum Tracks w/Drum Machine | mentalmusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-02-2002 06:39 PM |
