Old 10-09-2013, 11:51 AM
dave911's Avatar
dave911 dave911 is offline
Default Haswell build
i7-4770K
Cooler Master V8
Gigabyte GA-Z87X-UD5H Z87 LGA 1150 2-Way SLI Dual LAN ATX Motherboard
Kingston HyperX Beast 16 GB Kit (2x8 GB) 2400MHz DDR3 PC3-19200 Non-ECC CL11 DIMM XMP Desktop Memory KHX24C11T3K2/16X
Rosewill SilentNight Series 500W 80 Plus Platinum Certified Modular Design ATX12V/EPS12V Power Supply SilentNight-500
Runs tracking at a 32 buffer with a LS56 and large (50+) plugin/track counts at 512-1024.
Overclocked to 4 Ghz static.
PT 10.3.7 an 11.02 running with no crashes or lockups.
The regular PT OS settings.
DPC Latency 30-60 microseconds.
Only issue with the motherboard is the supplied driver for the Marvell onboard disk controller is junk and throws huge DPC spikes.
The Intel controller handles 6 drives so I just disabled the Marvell, but a new driver might be available.
The memory is rated at 2400, but I and others found it runs better at XMP profile 2 -2133
If you use a FW interface this MB has a built in VIA chipset that passed the Focusrite tester.
Also has a PCI slot.
Very easy build and stable.
Some info. on why I picked this over Ivy Bridge-E
http://www.anandtech.com/show/6355/i...architecture/8
Would have waited for the 8 core Haswell -E's next year but my old system had other ideas.
YMMV!
"In theory there is no difference between theory and practice. In practice there is." - Yogi Berra
Old 10-14-2013, 07:09 AM
Doobielespaul Doobielespaul is offline
Default Re: Haswell build
Hey you are able to run pro tools on a haswell 4770k?
I was gonna try a 4770k + x87 d3h buildv for pro tools 9. How has your setup been working ?
Sent from my SGH-I337M using Tapatalk now Free
Old 10-15-2013, 06:15 AM
mlange's Avatar
mlange mlange is offline
+1 for Haswell info
________________________
www.PlethoraTone.com
PlethoraTone Studio Video Tour
At PlethoraTone:
Intel Core i7-4960X, Asus P9X79 LE, W7 Pro 64-bit, 16GB DDR3,
Avid HD Native, Pro Tools HD v10, 4/192 I/O, 2/UAD-2 QUAD,
Tascam US-2400, Exponential Audio, PSP, Kush, Slate Digital,
Waves Mercury, PA, Melodyne, Antares, Audioease, SoundToys
Old 10-15-2013, 06:22 AM
Le bump
Old 10-15-2013, 07:49 AM
EGS's Avatar
EGS EGS is offline
Wow. Great job, dave911 !!!
Desktop: PT 2019.6 / Win 10 / GIGABYTE GA-X58A-UD3R / i7-980X hex @ 3.9GHz / 32GB / Focusrite LS56
Laptop: PT 10 / Win 7 / HP ProBook 4730s / i7-2630 / 8GB / U-PHORIA UMC1820
Info/Services link
Old 10-15-2013, 09:53 AM
YYR123's Avatar
YYR123 YYR123 is offline
Nice are you running this as a hackintosh are you running Windoze?
Daniel
Old 10-15-2013, 11:36 AM
dave911's Avatar
Running W7, be interesting to see a hack though.
Old 10-15-2013, 11:38 AM
dave911's Avatar
PT10 and 11 run fine, don't know about PT9 or what any other hardware combo might do.
Old 10-16-2013, 05:36 PM
mlange's Avatar
YMMV!
That's a great read, Dave - thanks.
So how many cores does PT 10 see with your current config?
At PlethoraTone:
Old 10-17-2013, 06:37 AM
dave911's Avatar
PT10 sees 8, I'm using 7 as host processors at 99%.
New Imacs Out Today (Haswell) nst7 macOS 2 09-24-2013 07:38 AM
Any Haswell builds? dave911 Windows 3 09-13-2013 08:42 PM
DPC Latency in Haswell dave911 General Discussion 8 07-17-2013 08:08 PM
Haswell technical question for Avid darbyclash34 Pro Tools 11 11 06-03-2013 04:01 AM
Haswell Processor - TSX or not dave911 General Discussion 2 04-24-2013 05:19 AM
