  #5831
Old 06-27-2014, 08:04 PM
Shan's Avatar
Shan Shan is offline
Default Re: i7 Builds - Specs and Results
Originally Posted by Mark Madness View Post
So yeah if anyone could give me any direction of what kind of specs I should aim for to have a powerful enough PC.
The first two posts of this thread have all the info.
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
  #5832
Old 06-28-2014, 09:48 AM
The Weed's Avatar
The Weed The Weed is offline
Or get in touch with guitardom for a custom build.
Cheers,
Demos: brucehayward dot com
Source-Connect: brucehayward
  #5833
Old 06-28-2014, 12:30 PM
WKG WKG is offline
Anybody bothering to run the Dverb2 test anymore? Just curious if it's still a relevant benchmarking tool with PT11 etc.
I7-4930K, X79-Deluxe, 2133 32 GB,
GT640, 512GB 860 Pro, 1TB Evo, WDB 2TB X2,
Win 10 Pro, PT Ultimate 2019.6 REAPER 5.963
RME, Daking, ISA, Sytek, BLA
ASUS N71Jq i7 940xm 8GB DDR3
PTHD 12.1 REAPER - Win 10 HP
  #5834
Old 07-17-2014, 11:08 PM
Shan's Avatar
It's more relevant than ever for finding issues. And the results with a bit of history. PT 11 needs to run the Dverb 3 test, which adds disabling Dynamic Plug-in Processing during the test...or maybe that should be called the Dverb 2.5 test.
Shane
  #5835
Old 08-16-2014, 09:41 PM
zedhed's Avatar
zedhed zedhed is offline
Originally Posted by tatothekid426 View Post
There are six SATA 6GB/s on the Asus Sabertooth X79 - two provided by the Intel X79 chipset and four by the Marvell 9128 SATA Controller. I just bought a Samsung 840 Pro 256 GB for OS, Pro Tools, etc but I’m not sure which of the ports above would be the best option for connecting it. Can someone point me to the right direction on this subject?
If haven't done so already, make sure you download and install the 'Samsung Magician' software to tune the SSD/OS to get best performance.
Too much blood in my drugstream
Gigabyte X99 SOC Force Mobo Bios vF6d
Intel Core i7 5930k socket 2011 v3 @ 3.50GHz
32GB DDR4 Crucial RAM
System: Samsung M.2NVME SSD 960 Evo
Record: Samsung M.2NVME SSD 960 Evo
Samples: Samsung SATAlll SSD 840 Pro
Storage: 2x Samsung SATAlll SSD 840 Pro
EVGA GeForce GTX 750 Graphics
PT 11HD (v11.2.1) Omni s/pdif w Eleven Rack
HD 96I/O
Win 8.1 Pro
  #5836
Old 08-20-2014, 04:30 PM
spenner spenner is offline
Hi everyone,
My i7-930 finally kicked the bucket after several years of great use. Here are the new build and Dverb test results:
i7-4790K LGA 1150 w/stock cooler, ASRock Z97 Extreme, 8 GB Corsair XMS 3 CMX6GX3M3C1600C7, onboard graphics via DVI, C: and Audio drives - WD RE4 WD5003ABYX 500GB 7200 RPM 64MB Cache SATA 3.0Gb/s, Cool Master HAF full tower - all case fans running (4 total), Win 7 64 bit SP1, Pro Tools 9.0, Dverb score - 24/48 session, playback engine 1024 buffer 8 processors, 83 tracks, 414 Dverbs.
Note: I performed the standard Avid optimizations and have not changed anything in the BIOS yet. The RAM is set to auto and running at 1333.
I am very please with how solid this setup is with PT, particularly using the onboard graphics. Not one glitch so far. The RAM and hard drives are old and from the previous build; will upgrade to SSD drives soon.
__________________________________________________ ________
Testing the new build with a mix done on the i7-930 - other than the new motherboard and processor, same components and Profire 2626 interface connected via a Texas Instruments Firewire PCIe card.
Just for the hek of it, on plugin inserts F-J, I added Waves SSL E Channel, Ozone 4 and Native Instrument's VC 2A on all audio tracks. Also, I placed 5 instantiations of both Guitar Rig 5 and Eleven LE on 5 inserts (and loaded random presets).
128 Buffer, 7 processors. Playback has been running for 20 minutes without a glitch. With session running, I have inserted plugins, tweaked parameters, etc. No glitches so far.
  #5837
Old 08-22-2014, 09:23 AM
Escape Escape is offline
Spenner thank you so much for posting this.I will go the 1150 z97 route at the next 1-2 months.One question though can you tell me your cpu temps running the dverb test after 20 minutes,also did you max out the cpu when doing the test?Thank you
  #5838
Old 08-22-2014, 04:28 PM
You're welcome. The combo is definitely working for me.
1) The photo posted above (with a ton of plugins added to a normal session for testing purposes only), and 2) the Dverb score posted above... Core Temp gave max readings of 76°C and 84°C respectively. I absolutely do not run anything (real world) close to those sessions! Still, I will add a 3rd party cooler to keep temps as low as possible.
FWIW, my room temperature is 77°F. Today I mixed a 64 track session with automation and 50+ plugins - 128 buffer, 7 processors. Core Temp readings did not go over 55°C. Again, stock CPU cooler.
Playback, for the 5 minute Dverb 2.0 test, was interrupted for the first time after I reached 415 Dverbs; yes, CPU maxed out. Perhaps BIOS tweaks would have yielded a higher score. However, I wanted to test out of box with no BIOS tweaks to see how it would perform. I'm fine with 414 Dverbs!
The mix session (on the photo posted above) ran for 60 minutes non-stop on 128 buffer, 7 processors (I was only 20 minutes in when I posted yesterday). Several times in that time period, with session running, I removed and inserted plugins. Pro Tools 9.0 did not flinch.
Z97 mobo, no BIOS tweaks, onboard graphics, mixing on 128 buffer... I am waiting for PT to make a fuss, but it has not so far.
  #5839
Old 08-22-2014, 07:20 PM
Thank you so much.I will add a noctua cooler probably.
  #5840
Old 08-27-2014, 03:45 PM
pianosound pianosound is offline
I've done something similar to spenner, check out my sig. I decided not to use the stock cooler, and chose the Enermax ETS-T40-TB CPU cooler, 35.00 at Newegg, (using a fanless GPU that runs 4 monitors, it really helps. Extremely quite and very cold! As for testing to this point, nothing huge but everything fast and responsive!! Love the new Haswell 4790K CPU (LGA 1150, 4.0). With the Samsung SSD its crazy fast!
Mike
Intel Core i7 4790K 4.0GHz | Asus Z97-Pro LGA 1150 Intel 6Gb | Corsair Vengeance Pro 32GB DDR3 2400 | Asus GT640 Silent 2 GB GDDR3 | Samsung 850 Pro SSD's, WD Caviar Black HDD's | PSU Corsair 750W ATX12V | Windows 10 | Presonus Studio One | 003R PT's 12.8 | Waves Platinum | Ivory/Piano | Berlin Woodwinds, Nocturne Solo Violin | SPITFIRE Solo Strings | EastWest Hollywood Strings, Brass, Pro Drummer, and Stormdrum 2 | VSL | Vienna Ensemble Pro | M-Audio Code 61, FaderPort 8 |
Best Core 2 Series Desktops-Results and Specs sunburst79 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2416 02-19-2013 07:49 PM
new to pc builds chazc080488 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 10-18-2011 07:10 PM
any p45 builds fofif5792 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-09-2008 12:47 PM
OSX "builds" Richard Barrie Pro Tools TDM Systems (Mac) 2 10-18-2004 08:37 AM
