Old 04-18-2006, 02:52 PM
Brandonx1 Brandonx1 is offline
Default Re: DV Quicktime look really bad in PT 7
Okay, I'll give it a shot. I just want to know if your digitizing video with a Canopus ADVC-110, looking at the movie in PT 7 and it looks like a good quality video with crisp edges? I can look at the same video with the QT player and it looks fine. The only time it looks bad is in PT 7.
Brandon
Brandon Howlett
Vibe Audio Post, Inc.
Re-recording Mixer
Custom Build CPU, HDX 1, Omni, 192 I/O Digital
S6 M10 24 fader
Satellite Mac Pro, HDNative, 192 I/0
Black Magic HD Extreme
Old 04-18-2006, 05:47 PM
Hi Digi,
Man, I just can't make DV qt look high quality in PT 7. I just re-installed QT 7 with the latest build. It actually made the DV movie play correctly in the QT player but when I open a session in PT 7.1.cs6 and impost the video, it looks really pixelated. I can't believe Digi can't repo this. Can some other person repo this for digi?
Thanks,
Brandon
Brandon Howlett
Re-recording Mixer
S6 M10 24 fader
Old 04-19-2006, 08:52 AM
reefer reefer is offline
Hi
I get the same problem running Q-time 7 with P.T 7.0 cs6
The picture looks fine when i bring it up in Q-time but very pixelated in P.T it self.
Old 04-19-2006, 11:47 AM
Thanks Reefer,
Anyone else. I don't understand how digi can't repo this.
Brandon
Brandon Howlett
Re-recording Mixer
S6 M10 24 fader
Old 04-19-2006, 11:54 AM
DigiTechSupt's Avatar
What application are you using to digitize the video?
Avid Audio Tech Support
Support FAQ
  #16
Old 04-20-2006, 11:06 AM
The videos are all digitised on a Mac using imovie or FCP. DV Digitised with MovieMaker look fine.
Peace,
Brandon
Brandon Howlett
Re-recording Mixer
S6 M10 24 fader
  #17
Old 04-20-2006, 02:03 PM
One more thing, I've noticed with QT set to safe mode (GDI only) in the Quicktime settings, My DAW shows around double the processor usage as in DirectDraw with Enable DirectDraw acceleration and Enable DirctDraw on secondary monitors checked. So, I think I'd like to leave DirectDraw on in QT.
Brandon
Brandon Howlett
Re-recording Mixer
S6 M10 24 fader
  #18
Old 04-24-2006, 12:14 PM
I'm bumping this one up. I'd still like to get a good answer on this one.
Brandon
Brandon Howlett
Re-recording Mixer
S6 M10 24 fader
  #19
Old 04-25-2006, 03:03 PM
Ok, one last question - what codec is being used in the original movie? I need to know as many of the specs as possible, so that we can try to find some way to reproduce this. So far we've not been able to, but we may not have come across the same codec and settings that you're using.
Support FAQ
  #20
Old 04-25-2006, 03:48 PM
Thanks for trying to work this out. So, I opened up QT and went to window. I says
Format: DV/DVCPRO - NTSC 720 X 480 Millions
16-bit Integer (big Endian) Stereo 48000 kHz
Movie: 29.97
Playing FPS: changes between just ovewr 30 FPS and just under 30 FPS
Data Rate: 30.31 mbits.sec
Normal Size: 720 X 480 Pixels
I'm using QT 7.0.3
Hope this helps.
Brandon
Brandon Howlett
Re-recording Mixer
S6 M10 24 fader
QuickTime 7.6 lego 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-21-2009 07:55 PM
Quicktime Crash on Export to Quicktime Movie Yosemite 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-28-2007 01:44 PM
HELP! HD 6.9.x on 10.4.x with quicktime 7.x ??? brendo_91 Pro Tools TDM Systems (Mac) 1 07-24-2006 11:47 AM
Quicktime Wainui Pro Tools TDM Systems (Win) 6 01-29-2004 09:28 PM
Major Problem Transfer TDM MAC Quicktime to PC Quicktime audio1420 Post - Surround - Video 0 04-22-2003 10:41 PM
