Old 04-01-2014, 07:29 PM
joey8989896 joey8989896 is offline
Default Digi 003+ is making my computer really hot! Kernal_task is using all my CPU
MacBook Pro
Model: 13-inch, Mid 2012
Processor: 2.9 GHz Intel Core i7
Memory: 8GB 1600 MHz DDR3
OS: 10.9.2 & 10.8.5 (on separate hard drives)
Interface: Digidesign 003 Rack+ Factory (8 mic inputs)
Software: Pro Tools 10.3.8 & 11.1.2
Drivers: 11.1 for mavericks & 10.3.3 for mountain lion
Peripherals
Firewire 800 > OWC 1TB HD> Firewire 800 to 400 cable> 003+
-I've tried all possible cable combinations with no luck including:
computer > 800 to 400 cable > 003+
comp > 800 to 400 adaptor > 400 cable > 003+
comp > 800 > HD > 400 out from HD > 003+
Audio Drive: USB 3.0 > WD 1 TB HD (I've tried using 2 other drives with no luck)
I have tried all troubleshooting methods described in the forums sticky.
I have taken my computer in to apple for a hardware inspection (and passed).
I complied with the READ BEFORE POSTING sticky.
What happens:
Any sound that is played from the computer to the Digi 003+ results in the computer overheating and kernel_task goes up to ~100%. This results in the computer being less responsive and therefore can't use nearly as many tracks or plugins.
More directly it has to do with anytime the HOST 1394 green light goes on on the front of the 003+, like when pro tools keeps it on or you empty the trash bin and it makes that trash sound or a youtube video.
I am not the only one with this problem. I've been searching for the answer all over the internet for months now and no one seems to know the answer.
Please help moderator! Thanks
Old 04-02-2014, 01:51 AM
AntonTsygankov AntonTsygankov is offline
Default Re: Digi 003+ is making my computer really hot! Kernal_task is using all my CPU
Same thing....
I tried:
comp > 800 to 400 cable > 003+ (Kernel_task is about 70%)
comp > 800 to 400 adaptor > 400 cable > 003+ (Kernel_task is about 95%)
comp > 800 to 400 cable > MOTU ULTRA LITE FIREWIRE (solves all problems...Kernel_task is about 2-4%)
comp > USB > APOGEE DUET (Kernel_task is about 8-12%)
I really love to use Genuine Pro Tools 003R+ hardware with PT11 and Mavericks instead of third party manufacturers.
Could you please fix the drivers? I used same setup with Pro Tools 9 and 10.6.8 Os and had zero problems.
Old 04-02-2014, 07:33 AM
JoelG's Avatar
JoelG JoelG is offline
I'm not sure this is related but:
Mac OS X 10.9.1 requires Pro Tools 11.1.2 or higher
is this happening on both versions of OSX, or just Mavericks?
Joel
Jam Space:
HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro
Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro
Rig:
Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM
Old 04-02-2014, 06:18 PM
Yes it is happening on both versions of osx
Old 04-12-2014, 05:57 PM
Joel
Hi Joel, have you heard anything back from your people on this issue? My computer is still getting really hot
Thanks
Old 05-01-2014, 10:59 AM
Eekay Eekay is offline
Bumping this, I have the same problem. I love this interface though, would be a shame if I had to sell it.
Old 05-09-2014, 12:17 PM
Guys I fix my problem for the time being. I uninstalled the Avid 003 11.1 driver and installed the 10.3.3 driver and I'm using Pro Tools 10 and. I'm not getting the kernal task spike anymore for now
Old 05-09-2014, 12:34 PM
Cool ill try it out!
Old 07-12-2014, 08:47 AM
dominic_1982 dominic_1982 is offline
Did anyone using Mavericks find a solution to this (without having to revert back to Pro Tools 10 after paying for 11 a year ago)? I think upgrading to Mavericks is possibly where my problem started (maybe not) but didn't experience the problem 'til months later as had a long period of time where I din't connect my 003 Rack.
Old 07-12-2014, 04:04 PM
mazzie mazzie is offline
Isn't usb3 an issue? Read on here somewhere about this do a search! I run a mac pro 5,1 with 003r with no problems.
Cheers
Mazzie
Need help making connections to my Digi 003? Mainstream 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 12-07-2010 08:04 AM
Digi 001 computer out to computer Cable Question dbguitar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-28-2004 03:29 PM
making Mbox the main audio out for my computer.... meeatt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-25-2004 01:37 PM
Digi 001 - Making Outputs MONO? atrest 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 09-17-2003 08:14 PM
Making demos on Digi 001 jamlaw 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 27 03-31-2003 04:04 PM
