Old 06-11-2003, 08:18 AM
Haniel Trisna Haniel Trisna is offline
Default "Back To Origin" for bwav
Is there an operation in PT for snapping a sound clip back to it's timestamped original location a'la Nuendo ? Like when we import a bunch of files from other editors and select them and do "Back to origin", then those clips snap back to its originally created time thus are now in sync with each other.
thanks
Haniel Trisna
Mixermaster
mixermaster.com
Old 06-13-2003, 11:33 AM
O.G. Killa's Avatar
O.G. Killa O.G. Killa is offline
Default Re: "Back To Origin" for bwav
That is what the Spot feature is for.
Import all your audio into the Region list. Hit [F3] to Select Spot in the Upper left corner of the edit window. Click and drag the audio files from the region list one at a time onto the tracks. As you drag them a window will come up. At the bottom of this window choose "Use original time stamp". It will then place it in the EDL where it was originally recorded.
If you already have audio in the tracks, I believe if you choose spot and then go to move them the same window will come up. Choose "Use orginal time stamp" and it will put it where it is supposed to be.
Derek Jones
Sound Engineer / Producer / Composer
Derek Jones Linkedin
Megatrax Recording Studios
Megatrax Studios Yelp Page
A-list Music Artist Page
Old 06-14-2003, 12:37 AM
Great !!
thanks a bunch !
- Haniel Trisna
<font size="2" face="Verdana, Arial">
Haniel Trisna
Mixermaster
mixermaster.com
Old 06-15-2003, 11:27 PM
Dan Pinder Dan Pinder is offline
Unfortunately there isn't a way to select a load of regions or files and make them all snap to their original timestamp in one go. Logic does this too.
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? bashville Pro Tools 10 5 03-23-2013 03:04 PM
hardware buttons for "preview", "capture" and "punch" evs Post - Surround - Video 1 12-06-2010 12:28 PM
FCP, .bwav and "expand to tracks" functionality mr.armadillo Post - Surround - Video 8 12-08-2009 11:45 PM
"Back To Origin" for bwav Haniel Trisna Pro Tools TDM Systems (Mac) 2 06-13-2003 11:26 AM
The future uses of "BWAV"format Tim R. Tips & Tricks 3 02-09-2002 12:27 AM
