Command 8 And Cubase
Hello Everybody
Does any body here uses the command 8 with cubase? I tried to do it had and had a litlle success The faders transmit midi but the transport keys dont... Is there a mixermap to command 8 for cubase? please Help |
Re: Command 8 And Cubase
If I were running Cubase, I would look into this sweet setup.
http://gearslutz.com/board/showthrea...threadid=18017 |
Man... I Wish I could afford that...
But what about the command 8 and cubase? |
I haven't run it with cubase as of yet . try calling the 800 # for Digi Tec support, they are usually pretty helpful in point to a proper direction |
I made a midi map and have notes on setting up transport...this should get started.
here'e the xml file. 2shared - download command8.xml and a note about the file and setting it up. 2shared - download command 8 cubase.txt |
here are the file links
xml file: http://www.2shared.com/document/VO_38e4o/command8.html notes: http://www.2shared.com/document/DLXc..._8_cubase.html |
the file command8.xml is no longer available at 2shared.com Did anyone involved in this thread get it to work? If yes - could someone be so kind as to make it available? I am buying from a friend despite warnings, and would like to prove the world wrong |
Cubase command 8 midi map here | xsdata | ProControl, Control|24, Command|8 | 31 | 01-05-2012 06:45 AM |
xml command 8 for cubase 5...help...i can't find it... | celestian | ProControl, Control|24, Command|8 | 0 | 07-09-2009 06:08 AM |
Command 8 with Cubase 5 with Vista...help.... | celestian | ProControl, Control|24, Command|8 | 0 | 07-02-2009 04:53 PM |
Digidesign Command 8 with Cubase Studio 4 - HELP!!! | stevethebeeline4 | ProControl, Control|24, Command|8 | 0 | 05-17-2008 07:52 AM |
Command 8 and Cubase | headclouds | ProControl, Control|24, Command|8 | 1 | 12-05-2004 05:51 AM |
