Pro Tools First "Cant post project"
I need help I downloaded and redownloaded pro tools first a few times nd every time I load it up and try to create a project it says creating project then says "there was an error posting the project" PLEASE HELP
Re: Pro Tools First "Cant post project"
Can you log into your Avid Master account and take a look at the projects section? If it attempted to create the project, you should at least see a project count of one. Also make sure you have enough space/projects available. There have been some cases where something went wrong on Avid's side and you need to contact them to reset your account, otherwise it would always show as full.
If you don't see any projects, then make sure PT is logging in using your master account username and make sure you are not being blocked by antvirus or a firewall. |
"Pro Tools quit unexpectedly" when opening (holding "n" no longer fixes it)[RESOLVED] | andrew24c | macOS | 4 | 07-23-2014 07:21 PM |
"Pro Tools not responding" error and a very "laggy" session! Help! | drumbumd | Pro Tools M-Powered (Win) | 0 | 02-10-2012 05:37 PM |
Pro Tools 9 "Pausing" when I press "Play" with Focusrite Scarlett interface | eanderso22304 | macOS | 3 | 11-23-2011 06:45 AM |
Pro tools 9 crashes at startup "Bus error" in thread "MainThread", at address 0x0 | danball | macOS | 2 | 09-26-2011 04:49 PM |
