Old 10-10-2018, 05:04 PM
Persyst Persyst is offline
Default Error: "Segmentation fault" in thread "MainThread", at address 0x0
I just installed the latest Native Instruments Komplete Kontrol 2.0.3, and have started getting this error when I QUIT Pro Tools 12.4.0, with or without KK plugin in the session.
Any suggestions on relieving this problem?
Thanks!!
System Details
Media Composer 8.4.5
Pro Tools 12.4.0
Mac Pro 2013, MacOS High Sierra 10.13.6
• 2.7GHz 12-core with 30MB of L3 cache
• 64GB (4x16GB) of 1866MHz DDR3 ECC
• 1TB PCIe-based flash storage
• Dual AMD FirePro D700 GPUs with 6GB of GDDR5 VRAM
File Type: jpg Screen Shot 2018-10-09 at 8.34.48 PM.jpg (18.1 KB, 0 views)
Old 10-11-2018, 05:13 AM
Default Re: Error: "Segmentation fault" in thread "MainThread", at address 0x0
You do know you're running a version of OSX that is not compatible with any version of PT right? That could well be the problem. Best to roll back to an earlier OSX that is compatible with your version of PT. According to the chart on this page: http://avid.force.com/pkb/articles/en_US/Compatibility/Pro-Tools-Operating-System-Compatibility-Chart
that would be any one of the following: 10.8.5, 10.9.5, 10.10-10.10.5,
10.11-10.11.6. Actually you'd better skip that last one (El Crapitan) as it's possibly the worst OSX ever unleashed on the public. And your iTrashcan was originally released with OSX 10.9.2 so that leaves you two options: either OSX 10.9.5 or OSX 10.10.5
Jack
QAPLA!
Old 10-30-2018, 06:23 PM
Aaah any chance you could recommend a good downgrade tutorial?
Thanks!!!!
System Details
Media Composer 2020.6
Pro Tools 2019.6
Mac Pro 2013, MacOS Mojave 10.14.6
Old 10-30-2018, 06:42 PM
Thanks!!!!
There are many great tutorials online. But first you probably need to work out what you are doing before finding a tutorial to do it. e.g. you may be better off upgrading Pro Tools.
You can likely fix the immediate problem by removing the .aaxplugin files. And did you ever try trashing prefs? Always worth trying.
Then if downgrading to a previous version of OS X, you need to work out where are you getting that from.... like...
The last full backup you made before upgrading... would be a great place.
A prior version of OS X you have previously downloaded in the Mac App Store (log in and check what is available to you there)
Or you may be going to need find it elsewhere, maybe have to beg Apple support to make it available to you. And finding those, also covered online in articles.
Old 11-09-2018, 08:22 PM
Ok thanks
System Details
Pro Tools 2019.6
Pro tools 9 crashes at startup "Bus error" in thread "MainThread", at address 0x0 danball macOS 2 09-26-2011 04:49 PM
"Segmentation Fault" "Main Thread" Error IceLitch macOS 6 08-12-2011 12:14 PM
"Segmentation Fault" in thread"Main Thread" at address 0x0 refuu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-13-2011 05:18 AM
"Segmentation fault" in thread "MainThread" WildHoney Pro Tools TDM Systems (Mac) 3 02-17-2011 10:40 AM
"Segmentation fault" in thread "MainThread", at address 0x0 digidub Post - Surround - Video 5 09-21-2010 01:09 PM
