Re: Artist mix pan knob not working
The driver is unified now but when doing the install, you only need to check the top option that covers the S3, App, and Artist series (so don't check the options below that)
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro S1 x 2, Fire Max11 x 2, Dock, iPad Air5 Mac Mini 14,12, 12 core, macOS 13.6.6 RAM 32GB, SSD 4TB, GPU 19 core QNAP TVS-872XT 148TB TB3 |
Did you try a complete restart of everything (computer and artist Mix)? Also, under System Preferences>Eucon Preferences, "Enable as External Workstation" should unchecked (off).
I was able to restore my system to the last Eucon and the Artist Mix is working again but I still have the problem with the knob.Yes I tried all that restart turned everything off.It just does not work with the new download or 3.7 but with the old 3.8 it works
do you mean in Eucon control under workstations 'enable as external workstaion should be off?That was on checked.Do you think that's why it would not work with 18.3
(when those are on, it is looking for remote control rather than a local application; that's for if you are controlling it from a surface that is already hooked to a main system; some of the surfaces can swap to control 4 different pro tools systems. But that is NOT what you want.)
#16
I think mine works with 'Enable checked..Yea I think you just said it wrong that's ok brother it is hard to do over the net.I sure appreciate your help
#17
I really didn't. Workstation mode is a different mode when it is being controlled by a secondary Eucon device. It should be unchecked.
#18
that is very very strange but my works with that checked and doesn't work if I uncheck it.I'm not saying you are wrong because I heard someone else say the same thing.I must have something set up wrong ..Ill check again...
#19
started my rig today and the pan knob is working againdon't know why...
#20
This has been reported by others. It affects me as well.
http://duc.avid.com/showthread.php?t...highlight=knob http://duc.avid.com/showthread.php?t...highlight=knob http://duc.avid.com/showthread.php?t...hlight=encoder
Pro Tools HD Native 2023.12 | HD Omni | iMac Pro 10-Core 3.0 GHZ - 64 GB - 2 TB - Vega 56 | Ventura 13.5 | Sonnet Echo Express SE II for PT HD Native PCIe and UAD 2 Quad PCIe card | Avid Dock and S1 |
Artist Mix: Pan knob not functional | Michael Carnes | Artist Series | 52 | 10-30-2020 08:56 AM |
Artist transport Assignable knob doesn't work | Raphie | Artist Series | 7 | 09-25-2017 07:43 AM |
Artist Mix encoder knob 1 does not work in Logic Pro | Gabaghoul | Artist Series | 8 | 08-24-2016 04:47 PM |
Assignable knob on Artist Transport? | asterix2k10 | Artist Series | 2 | 02-09-2016 11:43 PM |
Turn feature off on Artist Control knob. | VSOP Studios | Artist Series | 17 | 04-11-2013 05:49 PM |
