Old 02-11-2007, 09:46 AM
porkipine porkipine is offline
Default Workspace record volume settings
I just upgraded from a 15" Macbook pro to the 17" model. Transferred all my computer settings via firewire. When I open a new session, I'm getting the message about my firewire drive not being an audio volume. When I open the workspace, sure enough, it's set for "T" which is transfer. However, when I attempt to change it via the drop down selection, it won't do it. I get the message that it's not a valid audio volume.
Same thing goes for the actual internal drive. They are both set and stuck in "T" mode. Can't set em for playback either.
PT 7.1.1
Mac book pro 17"
M box 1
FW 800 drive
Old 02-11-2007, 10:48 AM
Slim Shady Slim Shady is offline
Default Re: Workspace record volume settings
Read the thread called "Audio Record or Playback Volume Error Info "
Old 02-11-2007, 12:07 PM
sunburst79 sunburst79 is offline
Trash your Digibase folder on the drive?
Run the Disc utility.
You might just want to trash all your prefs anyway
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 02-11-2007, 01:06 PM
I trashed all 3 files that digi recommends. Prefs, etc.... repaired permissions on the disc as well. Tried a second FW drive. Same thing, only recognizes the drive as a Transfer volume.
I'm beginning to wonder if I need to re-install the program. What a hassle as I don't have the ver 7 disc. I downloaded the upgrade from PT 6
Old 02-11-2007, 03:08 PM
Naagzh Naagzh is offline
PT 7.1.1
There's your problem. Intel Macs have not been qualified for 7.1, only 7.3.
002R PT7.3.1
MacBook Pro 2.33
OS 10.4.8
workspace - audio record volume juicytunes 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-17-2010 03:33 PM
"Session must be on an Audio record volume" - Workspace info jojo101 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-19-2007 05:07 PM
"Session must be on an Audio record volume" - Workspace info DigiTechSupt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 176 10-06-2007 10:55 AM
"Session must be on an Audio Record volume" - Workspace info DigiTechSupt Pro Tools M-Powered (Mac) 20 03-11-2007 06:23 PM
need help :workspace audio record volume nicolas paris 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-24-2004 05:51 PM
