DSP processor for PT LE
HEllo everybody!!
I'm working on PT LE with an Mbox 1 (wich would be changed soon..) and I have a few CPU problem when working heavy mixes. It doesn't hold.. I looking for a DSP processor wich would work on PT LE. Does anybody know any hardware I could get??? thanks for the answer Kernal |
Re: DSP processor for PT LE
I suppose the obvious ones are UAD, POWERCORE, LIQUID MIX. I think they all work with PT.
G5 dp 2.0Ghz, 2.5 gb RAM/ G4 Powerbook 15" 1.33mhz, 2gb RAM/ 002r/Lacie D2 FW800/PTLE 7.4 |
DON'T DO IT!!! I have had nightmare problems with hardware DSP processors and latency issues. Buy a Mac Pro, I have the dual 2.66GHz Intel mac and it BLAZES at low buffer settings. No DSP needed. THe biggest session I have going right now at 128 sample buffer size is 44 tracks and 80 plugins, and still have more power to go. In that particular session my CPU's run at about 50%, and they never get hotter than 100degrees F. I can even get it to bounce at 64 sample buffer setting if I am patient (sometimes it will drop out.) I can't seem to max it out. AND I only have 1GB of RAM at the moment... far less than most people on this forum have loaded into theirs. My Mac Pro has single handedly sent my mixing potential through the roof. Especially with the Music Production Toolkit this system blazes.
Mac Book Pro Retina 2.6 GHz i7 Quad | 16GB | OSX 10.8.5 | Digi 002 | Apogee Rosetta 800/96 | PT 10 | Waves Gold/RevMaxx V9 |
Waves APA boxes are another option. I have the APA 44-M working well with PT's 7.3.1. Latency is unavoidable though, so you need to keep check of the sample shifts. Not all of their plugs work with the APA boxes also.
NNNNNNNNNNNOOOOOOOOOOOOOOOOOOOOOOOOOO!
TRUST ME!!!!!!!!! Stay away from the Waves APA's... I had one and the latency is not only unavoidable, but unbelievably annoying! Plus all the headaches of setup and configuring, and lost time restarting and trouble shooting. URGH!!! Even when loading plugins onto the APA it still strained my CPU! Whats the point? $1500 for the APA plus $975 for Waves Gold Native= $2475 Brand new Mac Pro dual 2.66Ghz= $2499 I returned it directly to Waves and bought my Mac Pro!!! Trust me its all you need! No DSP needed. Almost no latency issues!
I have not heard a single glowing report from anyone who has bought a 3rd party DSP box for PTLE.
The few that do say nice things only comment on the sound quality of the plugins, not that it is easy or convenient to use. DP, Sonar, Cubase and Logic users don't seem to have the same problems because those apps have PDC. Until PTLE gets full plugin delay compensation, it will be a chore to analyze each track and make the necessary time adjustments for those external boxes. It seems that OddsAre is speaking from experience - and he is echoing sentiments I've heard as well. Are you maxing out a MacPro? Even my dual G5 is pretty powerful.
Larry PT 2021; MacBookPro M1; 16GB; Spectrasonics; Native Instruments, Toontrack, Waves...too many plugins. |
The returns have been real inconsistent with LE setups. |
UAD-1 card / plug-ins are good also. You can use a combination of both if you wish. The newest version is very stable within Pro Tools and you receive a free VST to RTAS wrapper on purchase.
It's funny you got all those replies yet, you haven't reported what computer do you use for your current setup...
If you're on a G4/Single G5 as others suggest - Go with MacPro or any fast computer. DSP Future: Even Digidesign's Instruments are all RTAS those days... ANY DSP you'll get will have latency and will require some CPU. And PTLE doesn't have Delay Compensation so it's pretty much not that effective. I have 2 APAs... Waves advantage is the fact all plug-ins for the APA are capable of running on both - native/dsp. But as written: - Usually you spend a lot of time troubleshooting. - Latency is extensive. - Some CPU Usage is still taken by those processors. Bottom line, Get a better computer - Cheaper, better, upgradeable ...
Just wanna do music, RA. |
1 processor performance better than 2 processor | dirtdog | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-29-2006 07:30 PM |
Dual processor Mac vs. Single processor ? | gtrplyr1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-26-2004 10:12 AM |
Single Processor Vs Dual Processor Mac | Alagu | Pro Tools TDM Systems (Mac) | 8 | 03-13-2004 11:18 AM |
newbie needs help---dual processor vs. single processor G4 | andtsorn | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 15 | 05-13-2003 05:05 PM |
G4 (1 processor) vs G4 dual processor | lgs | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 10-06-2000 05:21 AM |
