Old 08-31-2017, 10:59 PM
jacko's Avatar
jacko jacko is offline
Default Disable input monitoring for punch ins with HD hardware?
I'm doing cue mixes from an analogue console. Pro Tools HD famously does not have the ability to disable input monitoring for armed tracks unless 3rd party audio interface is used. How do you efficiently make punch ins without double monitoring in musicians headphones in such scenario?
Avid people, have you considered a feature that would mute the inputs on record armed channels?
UAD Apollo x16,
UAD Apollo Twin Duo,
UAD Octo Thunderbolt,
Mac Mini i7 2018,
Reaper DAW,
Presonus Faderport,
Arturia Beastep for DAW control,
Former Pro Tools HD user (from V7 until V12.6).
Old 09-01-2017, 12:17 AM
syMPh syMPh is offline
Default Re: Disable input monitoring for punch ins with HD hardware?
I'm not understanding the problem, it doesn't cause a issue here with a console workflow... I put the track in question into record and audio plays back form takes while rolling and becomes live once I punch in... if you want the old take to play back parts of the take just put it on another track and keep play active and record onto another track and mute the output of pro tools if you are monitoring on the console... if you want to go with one track workflow don't monitor form the console on the recorded track and simply use pro tools as normal... with the Rec button lit for playback it will play that audio to your console channel and when you punch the audio from "live" will go through tools and playback on same channel on console... plenty of options to choose from - in fact much more than working natively :)
System Details
Old 09-01-2017, 06:06 AM
jacko's Avatar
I know all the options. Sometimes just missing an additional one! :)
UAD Apollo x16,
Mac Mini i7 2018,
Reaper DAW,
Presonus Faderport,
Old 09-16-2017, 10:25 AM
Extreme Mixing Extreme Mixing is offline
I'm not sure I'm understanding your question completely, but try this...
In Preferences, you can unlink record and playback faders. So set the level for playback. Then put the track into record, and pull the fader all the way down. Now when you punch in, the fader will mute the playback coming through Pro Tools, and you will hear the live monitor feed from your console.
If you're using PT HD then the latency should be acceptable to the musicians. Your method sets recording back 50 years. The ability to monitor through tape is what has defined recording workflow forever. You're reinventing the wheel and I'm wondering why???
Steve
Steve Shepherd
Extreme Mixing
Old 10-04-2017, 07:47 PM
Dan IceWood Dan IceWood is offline
OR the simple option is to go to preferences and select
"Mute Record-Armed Tracks While Stopped"
Any way to disable Input Monitoring for console use in PTHD? Dloh31 Pro Tools 10 16 11-27-2016 08:38 AM
Disable input Monitoring Karl Engel Tips & Tricks 2 01-17-2006 03:40 PM
can I disable input monitoring ? frenchman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 09-16-2005 06:24 AM
how do i globally disable monitoring? stoogee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-21-2005 07:30 AM
Monitoring delay DISABLE!!! RIO B 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-26-2000 06:38 AM
