iLOK betweens
Good afternoon everyone.
I have just acquired another Mac Pro. Am I able to move my iLOK 3 remove my iLok and plug it in the other Mac to use. Of course it would only be used on one particular Mac at a time. I'm think this would be a great opportunity to / and a back to see how well my upgrade stability is, and have a older version on the ready.
MAC PRO 2010 5,1 3.46hex 128ram - MONTEREY 12.7.4- PT 2024.3 / 003 RACK SIGNATURE MOD / DIGIMAX FS / PCM90 2CHANNEL SPDIF
Re: iLOK betweens
Of course.
Thats the whole point of a physical dongle... the ability to use your purchase plugins/licenses anywhere by simply taking your iLok with you. Sent from my iPhone using Tapatalk |
Re: iLOK betweens
Not only can you move the iLok.. but if you are using these to do staggered installs for testing etc. then remember you can clone a drive and install that clone on the other Mac Pro after testing... as long as all Mac Pro meet minimal system requirements like boot PROM versions etc. You can even connect the Macs and go use target disk mode over Firewire to clone the boot drive between machines. All just a really nice way of ensuring that when you do run both systems at the same OS/Pro tools level that they really are identical.
These 5,1 Mac Pro are great... especially with upgraded GPUs, SSD, and USB 3.1 etc. |
Re: iLOK betweens
WOW ! I'm such a noob. Run both systems at the same time (don't follow?). like two computers working as one >? *sorry, I feel really dumbish right now.
Re: iLOK betweens
No one said at the same time but with the same OS/PT/Identical drives for when you switch between them. You can only use one computer at a time with one ilok license.
Re: iLOK betweens
Re: iLOK betweens
Right on, I grasped it now. Now what's the general consensus on containers ?. I haven't read much about any major problems except one person I believe who is not liking APFS.
Re: iLOK betweens
It's more optimized for SSD but it's robustness on HDD should be better than HFS+. If you have not already (sorry I've forgot, lots of folks here have...) I would consider moving to NVMe drives on your Mac Pro, M.2 drives in PCIe slot adapters, lots been written on DUC about that before, ... and if I did that I would definitely be running APFS on those drives (well you have no choice but to in recent macOS releases). And folks even have Catalina running on the classic Cheesegraters, but that may be a little more brain surgery than many folks might want to do. I'm not advocating you just leap in and upgrade macOS or change filesystems, but I am definitely saying you should want to eventually get to APFS... it's a positive not a negative. HFS+ was a tired old file systems, NTFS on Windows was more robust/advanced. Do some reading about APFS, especially to understand what containers do, and how nicely flexible they are. With iOS devices included this is one of the most widely used filesystems, in the world. And hopefully you are already making clone backups using Carbon Copy Cloner, and you can continue doing that with APFS drives. Now you have a second Mac Pro you could do all this playing there first. |
Re: iLOK betweens
When it comes to drive formating and partitioning just don't do anything rash, and be backed up. If you buy a new SSD, of course it must be APFS. I've used mac disk utilities a lifetime and I'm still learning about APFS.
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
Re: iLOK betweens
Thanks folks, greatly appreciate the great info.
New iLok License Manager Released - Now Supports iLok Cloud Managed Mode | unkJE | Licensing & Accounts | 0 | 10-10-2019 04:07 PM |
ilok issues - ProTools 9 crossgrade LE (Please install the iLok Client Software) | pauledwards | Windows | 3 | 09-10-2013 04:02 PM |
Plugin auth weirdness - guest iLok prevents internal iLok? | Scott Helmke | VENUE Live Sound Systems | 3 | 09-07-2011 07:06 AM |
Can You Transfer iLok Licenses To A New iLok If Your Old iLok Is Broken? | epu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 09-07-2009 03:51 AM |
Transfer iLok auth. from old iLok to new 003 factory iLok? | lamp | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 08-20-2007 07:05 PM |
